Hi All,
First off, some of you have probably read about my problems in another thread about leaking manifolds. To cut to the chase, I basically have a leak somewhere around the exhaust manifold or turbos on my R32 GT-R.
I have decided that I may as well be thorough and replace most of the gaskets, studs and nuts as I go. Anyway, I have (or will have tomorrow) everything I need except the studs, nuts and washers where the turbo meets the exhaust manifold. Crows Nest Nissan can get them, but its going to be over $200 for the eight studs/nuts/washers which is just outrageous IMHO.
Speaking to SydneyKid, he said that the studs are just a standard metric size and should be available through a generic nut supplier. He also said the stud pitch and length/height is listed in the workshop manual.
I feel like a bit of a gimp, but I can't for the life of me find the details in the workshop manual. I have gone through every single page of the english R32 Workshop Manual and the only details listed (that I can see) are tightening torques.
Perhaps they are listed in the R33 or R34 manuals, or the Japanese R32 manual: unfortunately I don't have those. Does anyone know what the specs for the studs are, or know where they are listed?
Again, I feel like a bit of a fool for asking, but I have drawn a blank :Oops:
Edit: So people know what I am talking about:
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/71848-turbomanifold-stud-sizepitchlength/
from memory they are M10 x 1.25 manfold studs
Interesting. They look similar to the turbo/dump studs I got from GCG today (they don't have the turbo/manifold ones :D), but seem a bit longer (which makes sense, since the Nissan part numbers are different).
Are you able to stick a ruler on it for length?
Cheers,
Lucien.
well i could not find a ruler or a tape measure but i hope this helps tou out its bout 50--55mm something like that
but i just bought some today must be replaced everytime you take the manifold off
Thanks mate: you've been a huge help: off the top of my head the standard is about 57mm or there abouts.
Off I got to find 8 x 57mm studs @ M10 x 1.25
BTW, I found this little printable chart quite handy for working out size and thread pitch :rofl:http://www.boltdepot.com/fastener-informat...hread-Gauge.pdf
Cheers,
Lucien.
Richard: I have spoken to Lee Bros. already. They don't have a stud with 1.25mm pitch on both ends, but if I get desperate the can help with a 60mm stud.
My problem is I need the studs before I take the car apart. I won't bore you with why, but if I take things apart and don't have the right studs I basically have to dump the car for two weeks.
Anyway, spoke to a muffler shop in Leichhardt and he reakons he has the right studs so I will try there first :rofl:
Lucien.
They must be replaced everytime you take the exi mani off? I re-used mine and they're fine (sr20). Is this only on the rb26 or all engines?
Should I be taking my turbo off and replacing them!?
The manifold to head studs are M10x1.25, but the turbo to manifold studs won't be that big (I'd be very surprised).   More likely M8x1.25.
Oh dear. The turbo to dumps are M10 according to GCG: wouldn't it make sense that the manifold to turbo one is also M10 (he says, looking at the M10 studs he just bought)?
blackrb20silvia: reakon you could line up that stud against a print out of the thread pitch chart I posted (about 4 posts up)? When printing in Acrobat, make sure scaling is set to None....
Edit: and the studs I just got are about 52mm long. Hopefully long enough :rofl:
LW.
Oh dear.  The turbo to dumps are M10 according to GCG: wouldn't it make sense that the manifold to turbo one is also M10 (he says, looking at the M10 studs he just bought)?.
Well they could be M10, seems rather big to me. Someone with a GTR turbo lying around should measure it - I can check tonight.
nah, as long as the thread on them is ok. it's your call. make a judgement when you remove/replace your manifold. if they are old and starting to deteriorate then replace 'em. I certainly wouldn't take your turbo or manifold off to replace studs that are working fine.
Lucien, if you get stuck there is no problem in cutting or linishing the studs. plus if they are just going onto the manifold/turbo flange then it probably wouldn't matter if they are 5mm too long.
ok first off when i posted there was no pic refering to the turbo flange bolts i posted bout the manifold studs which are M10 x 1.25 sorry to confuse
also it is highly recomended that when removing the manifold studs or turbo studs that they are replaced
1 because of the huge amount of expansion and contraction in that area
2 the last thing you want is when torqueing the bolts up is one to snap in the head if you are re-using
im sorry im just highly against reusing these bolts im not saying this to make money on it am i?
i have had alot of bad experiance with manifold studs and it is well worth the time and the money to replace when ever you take it off or it can cost tripple the amount if you snap them in the head please consider this when you change them please
what does a new head cost these days or the price of a helicoil kit or the labour of doing it what bout ezyouts well there not always ezy and if they snap too your in trouble
sorry to go on i just dont want iwells to have to pay twice when things go wrong!!!!
LW - Did you see my PM? All the info you need should be in there..
Yes, sorry, I was racing around and didn't have time to reply.
Again, I can't see any description for the pitch or size in the R33 manual, just like the R32 (unless I am blind). I guess it just assumes you will be purchasing them from Nissan.
LW.
Yeah, as per the other thread, I ran the part numbers by Crows Nest Nissan (hence I found out for the the 8 turbo->manifold studs/nuts it would be ~$200). I agree it means the width is the same.
And I think your right about them being M8s too. Hmph.
LW.
Oops. Replacing them, torquing? oh dear...I just put them on and hand tightened half of them, my mate did the other half. (engine to manifold, manifold to turbo, dumppipe)
Was I just really lucky that it all works ok? Either way I'm going to stop hi-jacking. Good luck Iwells.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
