Apparently we are going to hit close to $1.35 a litre by the winter.
If this happens the prices will flow on down to the price of every
thing we buy! Want petrol prices to come down? We need to take some
intelligent, united action. Philip Hollsworth, offered this good idea.
This makes MUCH MORE SENSE than the "don't buy petrol on a certain
"day" campaign that was going around last April or May! The oil companies
just laughed at that because they knew we wouldn't continue to "hurt
ourselves" by refusing to buy petrol. It was more of an inconvenience to us
than
it was a problem for them. BUT, whoever thought of this idea, has come
up with a plan that can really work.
Now that the oil companies and the OPEC nations have conditioned
us to think that the cost of a litre is CHEAP at .89 / .95 cents, we need
to take aggressive action to teach them that BUYERS control the
marketplace not sellers. With the price of petrol going up more each day, me
consumers need to take action. The only way we are going to see the price of
petrol come down is if we hit someone in the pocket by not purchasing their
Petrol!
And we can do that WITHOUT hurting ourselves.
Here's the idea:
For the rest of this year, DON'T purchase ANY petrol from the two
biggest oil companies (which now are: BP and Mobil). If they are not
selling any petrol, they will be inclined to reduce their prices. If they
reduce
their prices, the other companies will have to follow suit. But to have an
impact, we need to reach literally millions of BP petrol buyers.
It's really simple to do!!
Now, don't wimp out on me at this point...keep reading and I'll
explain how simple it is to reach millions of people!! I am sending
this note to a lot of people. If each of you send it to at least ten more
(30 x 10 = 300) ...and those 300 send it to at least ten more >>(300 x 10 =
3,000)...
and so on, by the time the message reaches the sixth generation of
people, we will have reached over THREE MILLION consumers!
Again, all you have to do is send this to 10 people. That's all. (and
not buy at BP and Mobil) How long would all that take? If each of
us sends this email out to ten more people within one day of receipt,
all 300 MILLION people could conceivably be contacted within the next
8 days!!! I'll bet you didn't think you and I had that much potential,
did you! Acting together we can make a difference. If this makes sense to
you, please pass this message on.
PLEASE HOLD OUT UNTIL THEY LOWER THEIR PRICES TO THE 80 cents a
LITRE RANGE.
It's easy to make this happen. Just forward this email, and buy your
petrol at Shell, Caltex, GAS. or Gull Outlets and drive past BP and
MOBIL Stations.
https://www.sau.com.au/forums/topic/71881-petrol-prices/
People will go whereever is easy, or they'll drive around getting the cheapest price, either way I don't think they'll be bypassing the two biggest companies.
Besides, some of us need the higher octane and stuff, or ju7st find their car runs a bit better on the ol' ultimate
I'd love to put pressure on the companies - but its a sad fact the prices are going to rise.
That said, I've been paying over 1.15 for well over 6 months now.
https://www.sau.com.au/forums/topic/71881-petrol-prices/#findComment-1325432
this goes around all the time. it wont work.
plus bp and mobil are the only ones worth running.
I tend to disagree... I find I get the same out of any 98 octane fuel.....
But each to his own I guess.....
The other thing I've got to say about this spam is, that it simply won't work.
And especially not out my way. We've got all three in the one street within metres of each other. The BP is ALWAYS the cheapest, no matter what. The Caltex fluctuates alot, but the Mobil, well, they're always over the top with their prices because they know they can still stay in business cause the police station across the road has to buy from them.....lol
https://www.sau.com.au/forums/topic/71881-petrol-prices/#findComment-1326337
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
