Hey guys,
I changed my gearbox oil the other day, after about 30 mins of driving, while I was sliding, the speedo and odometer just died.
It is a 89 GTST 4 dr. But it used to be an auto, it had a conversion in japan. I couldn't see a speedo cable running to the box, but it does have power cables. Does this mean it is a 33 box (electronic)?
Can someone tell me how to tell what box it is, then what I should be doing to fix it?
I am guessing that maybe when I put the hose in to fill it up I bumped the sensor? Or maybe it was co-incidence and something else happened.
First think I need to work out if it's electronic or cable driven.
Cheers
Chris
https://www.sau.com.au/forums/topic/71906-changed-gearbox-oil-lost-speedo/
Jump under the car and have a look if there is a speedo cable running from the rear of the gearbox on the speedo drive to the top of the fire wall near the brake/clutch master cylinders. Maybe the speedo gear drive on the sensor shat itself?? Don't think a RB25 box would be bolted up to your RB20DET, but could be possible.
You could also try taking the speedo cluster out and make sure the cable is firmly in place against the rear of the cluster.
Sorry about taking so long, I have been sick all week.
Ok, I have the numbers off the box.
rp71c
I found what I assume is the speedo cable, comes out just in front of where the gearstick comes down, runs up to the firewall, under a black cover (on the firewall)
i don't see how me changing the oil could effect the speedo - the cable is nowhere near the filler hole. But what are the electic cables that are locaded on the opposite side of the filler hole? Maybe I bumped whatever is inside the box?
So what order should I check things in?
Cheers
Chris
bump
i have seen the speedo cable snap at the cluster end.
get underneth and unscrew the cable holder and see if the drive is turning when u turn the wheel/taitshaft.
if it was auto it may have an electronic sender insted of the cable.
not to sure but.
a silvia one will fit but that depends on your diff ratio. for acuracy.
3.7: blue
3.9: yellow
4.1: red
4.375: white?
they can be really tight getting out some times
it sounds like a coincedance but. perhaps some metal got washed up into the drive when u changed the oil. jacked up on one side etc.
hope that helps
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
