Ok my GTR will be here next month, and I will want to increase the performance somewhat.
Basically i'm looking for 120+mph Terminals whilst retaining good driveability.
My plans at this stage are purely bolt on:
Deal with any other issues if & when they arrise;)
1. HKS2530 or similar low mount turbos, although the GT25/30 seems a lot cheaper...?
http://www.horsepowerinabox.com/HPIAB2/prod15.htm
Or can the standard turbos be rebuilt using larger 'steel' wheels with a HiFlow as I've had good results in the past with this?
2. SARD 700cc Injectors
Will these run with Standard ECU?
3. Power FC
Car already has full 3" exhaust and Pod filters, and GTR cooler should suffice.
Will this get me 450+rwHP and 120+mph terminals..?
Any other suggestions? or good places to buy parts?
Cheers
Lindsay
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/
450hp you will be pushing it with that set up, i own a R32 GTR its got HKS2530's,HKS Cams, Sard 700cc injectors, upgraded fuel punp, Trust drag intercooler, Twin 3inch system from turbo's, Link engine management and AVC-R on 20psi i pump out 330kw's
I want top mount twin turbo's for it then the power figure will really rise, the 2530's are limiting the power output but they boost up quickly and smoothly so its a fairly streetable car at the moment
I have seen a write up on the GT2530 turbo's and they say they are pretty much the same as the HKS turbo's apart from the price...
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/#findComment-1326464
No these will not run with standard ECU. Power FC is really the best option to take regarding the tuning a of a GT-R.
450hp at the wheels is possible with the the GT2530/ HKS 2530's but you will need to run some pretty big boost to get it. An easier to get this power output is to get some nice cams for the RB26 i.e. 276deg.
This will make your car have excellent top end without the need of running big boost i.e. 20psi (over).
Cheer AS
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/#findComment-1327704
Thx Guys.
It mentions what 'looks like' HKS 272 on the auction sheet!..?
Hopefully it does have the cams fitted :)
The GT25/30's seem a fair price from HPinabox, these are looking like a good option atm.
I do not want to turn it into a 'narrow high powerbanded' drag car, more of a flexible 'MC motorsport' club racer style thing.
So no one would reccomend the rebuilding of the standard turbos or knows anyone that has done this...?
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/#findComment-1328093
3. Power FC
Cheers
Lindsay
carefull with these turbos as they are not true bolt ons the compressor out and turbine out put are different to the gtr turbos and will require custom piping and bump pipes
pete
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/#findComment-1331972
550's with safc
Thx Simon.
Not really worth it then, as 550cc injectors are no cheaper than 700cc units and the SAFC is only about $500 cheaper than the Power FC......may as well spend the extra :(
You mean the GT25/30's..?
I am actually leaning towards GT-SS atm....closely followed by 2530s...Hmmm...decisions decisions :)
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/#findComment-1333154
Thx Simon.
Not really worth it then, as 550cc injectors are no cheaper than 700cc units and the SAFC is only about $500 cheaper than the Power FC......may as well spend the extra :mad:
I am actually leaning towards GT-SS atm....closely followed by 2530s...Hmmm...decisions decisions :cheers:
your right on the money
here a combo i will make 450rwhp(walk in the park) if tuned well
APEXI pfc (avcr is a good boost controller aswell)
320hp garret turbos or HKS 2530 (stay away from the horse power in a box set)
700cc sard injectors
Tomei poncams 260deg 9.15mm lift (or close to)
Tomei adjustable cam wheels (take the time to adjust them)
afms 20/25rb or z32
turbo back exhaust (twin 3" dumps into 3.5" single good place to start)
custom piping to the new from turbos to 80mm afms(3')
this combo is good for a great deal more than what you want but it will give great drivability and future development.
my car running 530rwhp
rich madsons r33 on good fuel have seen run 550rwhp+
and these cars on std internals have been going hard for sometime now with out a single problem.
hope it helps
pete :cheers:
https://www.sau.com.au/forums/topic/71949-gtr-powerup-qs/#findComment-1334455
