yes still forsale ,the problem is every one thinks its totally ****ed cause its so cheap but i just need it gone, thats y its cheap ,ive had 100's of calls but every one is from sydney and they say its to far to come and look so they dont come.
all belts have been changed but needs a service now for the sale price im not doing it either
i just want to gone simple
  • Replies 73
so timing belts etc been changed?(sorry dont know a thing about pistons)
oil,filters and spark plugs shouldnt cost much i rekon
but yeah im still interested even though its been a while
since i last said that
omg i cant believe this car hasnt been sold yet... man i swear if you were in the gold coast i would definately buy this car as im looking for a car now and this fits right in my budget...
man good luck with the sale and hopefully someone buys this car as its making me sad that i cant buy it everytime i look at this thread lol..
dude ill drive it to you for $100 fuel and air fare home easy
yea that sounds really tempting but only thing is i would like to check out the car first before buying, i wouldnt want to purchase a car without checking it out first incase i change my mind and it was a waste of time for you to drive all this way.
1 more week from today and then its off the market ill be keeping it so if your interested give me a call
Im still interested...
I cant call as i havnt payed the phone bill...
Will be selling my car this weekend...
Looking foward to your reply..
-Sindows
still forsale and back in trading post for last week with $13,000 on it
I just read that the rego is till november, im not sure if i can still take it....
Will keep in touch!
Hey,
Would you be interested in $11,500 plus a 1989 nissan exa to drive home in & keep (im in perth) the exa is worth atleast $3,500 as is, you could keep it as a run around car, or just sell it later on..
If your interested, email me at [email protected]
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
