Hey Guys
not sure if this is in the right area, but i just wanted to get some recommendations on turbo timers. I have just got my car imported and of course i am wanting to start doing things to it. first thing will be the alarm and i fgured i may as well get the turbo timer hooked up at the same time.
So what turbo timer do you recommend if you could get any brand and any model.
and secondary do you think its worth getting a fancy turbo timer or just something that does the job.
cheers
https://www.sau.com.au/forums/topic/71993-turbo-timer-recommendations/
I'd like to suggest the new Greddy turbo timer. Bought one about 1 month ago for $120 from ebay delivered. Not only is it a timer, but it can record your top speed, 1/4mile time, lap time, read your rpm, display your battery volts/status and the list goes on. Im happy with it...plus it has a blue screen...oooh
Hey Guys
cheers
i recommend a turbo timer... not a multi-display TT unit
reason?
will you actually use those features? will you even get them connected up?
i bought a $40 (older) apexi turbo timer of the forums and it is just a machine that lets the car 'run down'. took me 2 hours to install myself (only a screwcriver and electrical tape and on the side of the road in 30deg heat!)...
to get the fancy ones to work might need an auto electrition to hook up all that crap.
most people end up hiding their TT or putting it in an obscure location anyway which makes it impossible to see the screen anyway when driving to use the fancy features...
--> so, i say don't pay for what you won't use, but hey that's just my opinion!
cheers,
Warren.
Hey Guys
cheers
In all honesty why do you need one, for starters there illegal in Tassie anyway and you will get one very BIG defect for it and they now come under the new anti-hooning legislation when found on vehicles. Is it really that hard just to take it easy for the last few k's of your trip, sit in the car for another 30sec and then switch it off with the car in gear making it safe??? If you need a hand in hooking one up if you decide to go down that road then shoot me a PM and i'll help ya out but in all honesty and ask anyone that is in the racing/mechanical side of things they will tell you that a TT is just another way to waste money, my 2cents anyway
:cheers:
Well if I agree with not using one as much (i prefer to wind down my driving) but I have an Apexi Pen turbo timer. I got it for about $140. I've installed mine in the top right hand corner of the windscreen so it is hidden. It has features like battery voltage (useless cos of the factory gauge), O2 sensor voltage and Air/fuel ratio.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
