Brand new garrett GT Series BB turbo rated at 500hp. This is also
known as the GT30R 56T model
Front A/R is 0.6 (clears headers and Engine mount!)
Rear A/R is 0.82
4'' inlet with massive bell mouth to suck in plenty of laminar air
with surge shroud (similar to HKS 3037S)
2" outlet to suit intercooler pipe work
Turbine housing: GT30 non wastegated.
Inlet: T3
Outlet :GT30
Ball bearings allow the turbo spin forever, even when spun by hand and increadible reliability on high boost. I have seen these making 300 Rw kw on 17 PSI!
Item includes Garrett warranty from date of purchase.
Unlike bushed (STD wet floating bearing) turbos that need replacing/rebuilding
at 40,000 klm in performance applications, this will only require new oil seals
at 80,000 klm. This means long term savings!
Utilizing the latest compressor and turbine wheel design these have proved to
spool up even faster providing more drivability, stronger midrange power and torque with better reliability.
Inconel turbine shaft which is extremely light allowing quicker turbo response
and heat resilient this turbo is top shelf with no expense spared.
Recommended retail is $2960
Turbo only $1799
____________________________________________________________
HKS Cast manifold.
This will not crack! In addition it can be further ported, extrude honed etc for further improvement if need be. As you can see from the pic's, the design is pretty good. All runners are split as far up to the collector as possible which will give good top end and mid range performance. It even splits the wastegate gasses.
This has a T3 flange, but is big enough to be drilled for a T4 flange if required.
I usually use these with GT30/35/40 BB turbo's due to the T3 flange. Due to the low mount design, you minimize any unwanted attention from the cops! If you need more info feel free to Pm me.
ON HOLD
Brand new HKS Style wastegate to suit.
45mm Valve, silicon/nomex doaphram and 12 psi spring
$250
There is no warranty on this wastegate as I got it cheap and am selling it for what cost. It is NOT an original HKS wastegate (otherwise it would be $1300)
Manifold and Turbo combination $POA
RB25DET Nismo 550 cc injectors $750 cleaned and shipped
RB20DET/RB26 HKS 550cc injectors $750 cleaned and shipped
  • 1 month later...
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
