Brand new garrett GT Series BB turbo rated at 500hp. This is also
known as the GT30R 56T model
Front A/R is 0.6 (clears headers and Engine mount!)
Rear A/R is 0.82
4'' inlet with massive bell mouth to suck in plenty of laminar air
with surge shroud (similar to HKS 3037S)
2" outlet to suit intercooler pipe work
Turbine housing: GT30 non wastegated.
Inlet: T3
Outlet :GT30
Ball bearings allow the turbo spin forever, even when spun by hand and increadible reliability on high boost. I have seen these making 300 Rw kw on 17 PSI!
Item includes Garrett warranty from date of purchase.
Unlike bushed (STD wet floating bearing) turbos that need replacing/rebuilding
at 40,000 klm in performance applications, this will only require new oil seals
at 80,000 klm. This means long term savings!
Utilizing the latest compressor and turbine wheel design these have proved to
spool up even faster providing more drivability, stronger midrange power and torque with better reliability.
Inconel turbine shaft which is extremely light allowing quicker turbo response
and heat resilient this turbo is top shelf with no expense spared.
Recommended retail is $2960
Turbo only $1799
____________________________________________________________
HKS Cast manifold.
This will not crack! In addition it can be further ported, extrude honed etc for further improvement if need be. As you can see from the pic's, the design is pretty good. All runners are split as far up to the collector as possible which will give good top end and mid range performance. It even splits the wastegate gasses.
This has a T3 flange, but is big enough to be drilled for a T4 flange if required.
I usually use these with GT30/35/40 BB turbo's due to the T3 flange. Due to the low mount design, you minimize any unwanted attention from the cops! If you need more info feel free to Pm me.
ON HOLD
Brand new HKS Style wastegate to suit.
45mm Valve, silicon/nomex doaphram and 12 psi spring
$250
There is no warranty on this wastegate as I got it cheap and am selling it for what cost. It is NOT an original HKS wastegate (otherwise it would be $1300)
Manifold and Turbo combination $POA
RB25DET Nismo 550 cc injectors $750 cleaned and shipped
RB20DET/RB26 HKS 550cc injectors $750 cleaned and shipped
  • 1 month later...
    • It didn't save me any money! All it did was leave me with 3x 5L Engine oil bottles that have about 1-1.5L left in them 🤣
    • Have you tried one of those wash mitts @PranK? I find it works so much better than brushes on a stick for cleaning wheels. If fingers fit between the spokes, then can easily clean them with a mitt. I like Bowden's Own and use their Love Glove, as gay as it sounds. https://www.bowdensown.com.au/products/microfiber-range/love-glove That applicator looks super handy! Earmarked for next time I'm splurging on cleaning supplies.
    • A car always goes harder if it isn't yours ( e.g. rental, mum n dads, your mates daily when your deso)
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
