  • Replies 74
What are these DynoLog chasis dyno like compared to Dyno Dynamics?
Im not suggesting anything, just questioning? ;)
From the results i have seen on these dynos as opposed to dyno dynamics dynos:
1. They read lower then dyno dynamics dynos generally
2. You can't cheat the figures as easily as weather conditions are detected or dowloaded or something (can't remember exactly)
Just watched the video link(thanks R32_GODZILLA !);all I can say is "FAAAAARK!" Congratulations,Dave! Well,I'm off to the toilet;pass the Kleenex,someone? :whackit: !!
It all depends on how a DD dyno is configured as you have to put in your own weather conditions, hence shootout mode is used as a base sometimes. I can't tell you what the dyno at Ice would give as the car almost came off the rollers a couple times before we gave up trying and accepted a figure of 600+
The dyno at MAS takes weather readings 500 times per second during a run and makes the appropriate changes in the configuration to give an accurate reading.
What he said^^^^
Have ICE thought about getting different rollers or is it purely because of the power your car is putting down and the torque? Having said that i have seen some cars only making 230rwkw almost climbing out of the rollers due to some crazy lsd's they have been running (they weren't strapped down though).
You know you've got a really tough car when you can't get an accurate dyno reading from it :(
I would guess so. An Rb30/26 S15 in autosalon mag a while back with t51r spl was making a claimed 1600Nm of torque or more. My 33 made over 700nm of torque with a little under 400rwhp so i would believe that it's making this much torque.
What he said^^^^
You know you've got a really tough car when you can't get an accurate dyno reading from it  :)
The problem we have is that when the nos is injected, the power comes in so hard that the straps (3 of them) have trouble keeping the car down. The straps are tied to a bar attached to the dyno and it bends.
Is 1,550 Nm a true Nm figure? Is it comparable to the figures you read in the magazines.
AFAIK, this figure is accurate to the wheels. Magazines tend to quote torque at the fly as all tests are performed on an engine dyno.
There is another measurement of tractive effort but I have NFI what it translates to. All I know is that I'm making more than 13000Nm of tractive effort.
  • 2 months later...
:bonk: i have the record now lol
see you all at jamboree
heard about that.... congrats.
i have heard people saying that the car wasn't or couldn't be driven home though? what happened to it?
not taking the piss, i am curious as i don't know how long a motor could last with that kind of power?
Jamie
jas/slo32,
What was the total amount of power your car has made and was that in 4wd mode or Rwd mode.
Congrats btw and are you expecting more out of it or are you happy with what it is currently making.
i read on another forum it made 1070rwhp, correct me if i got it wrong.
i think its an auto gtst with rb30/26 in it if i am thinking of the right car.
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
