Hi guys i've just had a look at a GTR with Twin TRUST Td05 18G's.
the car also has a set of cams. don't know how big.
the car has external gates.the turbo's sit not in a high or low mount position, they sit about half way.
The car has a front mount with twin entry and is about 100mm thick.
Does anybody know for a fact on what the turbo's maximum is with good supporting gear?
I was hoping to get 400AWKW!
Also can you get local exhaust housings to fit the trust turbos. As i want a turbo wich has an outlet to the exhaust of about 2.5 inch.
Can you fit the exhaust housings from a TD06 25G to the TD05 18G,as i'm not to fussed about lag! if any of you can use examples and what power you have heard of or seen would be great.
cheers Ben
https://www.sau.com.au/forums/topic/72031-how-much-power-from-twin-td05-18gs/
hmm well i am not 100% sure on what turbos they were but i thought someone said twin high mount TD04's or TD05's i can get the exact details for you hopefully later but in canberra we just had a z31 fairlady with an rb26 and those turbos pull 510RWKW
