great info there Lucien. The reason i like arias over wiseco is they have a champered edge on the piston deck wheras wiseco have it square, the tampered edge will take alittle more punishment whereas I have seen wiseco's that have chipped the edge off and the metal has gone on to cause other problems!!! Je are also very good!!
I found this comparison quite interesting (keeping in mind its for Honda pistons, not Nissan RB-series):
http://www.importbuilders.com/pistoncomparo.html
LW.
There are 3 very important words in that comparison, "I sell Wiseco".
Tip #2 don't look at what WAS tested, look for what WASN'T. for example I would have though that hardness would be important in a piston, but no uniform hardness test results are shown. Perhaps they did test hardness and Wiseco came up not so good. After all if the Wiseco has the smallest tolerances and the lightest weight, then it is quite likely they are high silicone content and that introduces a number of hardness versus brittlenes and durability compromises.
We don't sell pistons of any brand, but we use JE in RB's and we have never had a piston problem.
There is no doubt that you raise an important point: both the piston brands he sells come out reasonably well. I still think that as long as you only use it as one piece of evidence it can be quite useful. There are also a number of threads across a range of forum about the comparison. Its worth doing a search on google to see some of the points made.
Its also intersting what you said about hardness: are there any other obvious metrics missing from that test that you can see?
Regardless, as I said I found it "interesting", but not the final word :)
Edit: I should also say, that at least the guy is upfront that he sells those pistons although you might argue with how he rationalises that :D
Lucien.
exxu1, i'm in the same boat as you and have been looking around for the best pistons i can get for a rebuild, and have come down to three braqnds HKS, WISECO and JE. The last two i'm still trying to find a good source to get pricing for but HKS are quiet well price and available. So if anyone knows a good place to buy wiseco and je from i would be very helpfull.
From what i am led to believe HKS use JE Pistons and Carillo Rods anyway. I Stand to be corrected though.
HKS, tomei, etc all use rebadged parts these days. The badge that says HKS usually adds a few hundred dollars to the price.
Who makes the cooling channel pistons for Tomei, because I haven't found anyone else selling them (although I haven't exactly looked hard)?
LW.
i wouldn't be so sure that all these big jap companies are just selling other peoples parts. I would think that their factorys do more than just print their names on cardboard boxes.
Luciens comment on the tomei pistons is one point.
Howdy pete,
thanks for your in put chaps.
When you find any more info Pete on where and how much let me know please because we are both experiencing the same thing. i did see some JE's on EbAY for around $1200.00 aus, but i did see alink saying that Wiesco's for RB out of Us for $600 US, but damn ,i cant find the threa
LW.
Tomei may add the cooling channel etc but i doubt they actually manufacturer all their items inhouse these days.
Outsourcing is the way the world works these days
YOu will find most companys use blanks then machine them to their standards... JE definately supplies to HKS whether HKS buy them complete or machine is anyones guess... I dont know about tomei, I rekon they would by blanks and machine them. HKS +Carillo rods is a definate, i have seen them in the flesh and can garuntee this!!!
In one of the HPI Vids they have a visit to the tomei factory where they show the pistons / cams being manufactured.
I think JUN make their own as well
Either way, I would use JE Pistons and Carillo Rods (HKS is the same) if you are doing a big HP Build.
Having said that, I think mario is using JUN parts? But probably special order (read: hell expensive) stuff.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
