Finally got a reply from Wiseco directly and is as follows how it may be of use (i have not contacted local supplier yet as only recieved email last night)
Dear Sir,
Thank you for your inquiry on Wiseco forged pistons. We do have those piston
kits available. The part numbers are k591m87 and k591m875. Unfortunately,
we can not ship directly across international borders. We do have a
distributor in your area that should be able to get either one of those kits
for you. Here is their business information:
Serco PTY LTD
34 Veronica St.
Capalaba 4157 QLD
TEL:617 3823 3833
Please contact our distributor for further assistance with our Wiseco
products. They should be able to answer any questions that you might have.
Thank you for your letter.
Sincerely,
Wiseco Piston Company
Je Piston cat.
http://www.jepistons.com/pdf/2005-sportcomp3.pdf
i have also sent email to Je pistons and i should get a reply soon
will keep you guys posted
pete
Mahle are a German company. Mahle motorsports are based in the US. Price depends on which piston but the Pro Series are around the $1800 mark from memory. Mahle owns ACL piston products so they should be available from National Parts. I've seen pictures of the RB26 pistons in D-sports magazine (US) so they definately make them.
The rep dropped in last week and had a new piston they are making for the EJ20 Subaru and it's a nice bit of gear. they are forged, skirt coated, radiused on all the square edges and have radial gas ports. The pistons also only run around .003" clearance which is nice for ring stability and noise. They look totally different to other brands of piston, they are a very dark grey colour and use the Mahle box-n-box design.
Mahle supply 4 out of 7 F1 engine manufacturers plus Mercedes, Porsche, Ferrari, BMW plus quite a few Nascar, IRL, V8 supercars etc.. so thats a fair indication of their quality.
Saying all that, as I said, we have never had a failure with either JE or Wiseco. One engine with Wiseco's has been running 2bar boost for over 2 years now without a piston letting go.
Thankyou very much for your info Proengines
Just for everyones benefit, i managed to find the Aust Distributor and guess what!!!! they are in Melb :headspin:
anyhoo here is their contact number & address
MAHLE Engine Components Australia Pty Ltd.
2 - 8 Oxford Rd
Laverton North 3026
Melbourne
Phone: +61 (3) 83 68 18 88
Fax: +61 (3) 83 68 18 04
http://www.mahle.com is their website as well.
2 - 8 Oxford Rd
Laverton North 3026
Melbourne
did you get a price on the piston kits $$ :rofl:
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
