I put a high tension lead in to check my timing and verified that my timing loop on the coil harness is off by 14 degrees. I set the timing to 15btdc like the FSM says and it ran like a pig, the motor also heated up quicker than normal (which sounds like retarded ignition to me). I put the light back on it and adjusted the CAS back to where the shadows from the bolts are (the original position) and it runs much better. The concern is that according to my timing light and 2 others my car is running 23 or 24 degrees btdc at normal operating temp. I don't hear any ping at all, and my SAFC is registering less than 70 at idle for the raw knock value.
When I had it at 15btdc the exhaust note was quite different and basically ran like shit until about 4000rpm. Now it runs like it should but I'm still concerned and don't trust the damned thing now, I don't want to lose a cylinder or two. The only thing I can figure is that the exhaust cam is off by a tooth on the timing belt. IIRC the teeth are approx 7 degrees per. I looked under the front cover and it 'looked' like the cams were timed right in relation to 0 on the crank but now I'm not so sure.
Anyone have any similar probs or ideas?
Thanks,
-Matt
https://www.sau.com.au/forums/topic/72042-rb25det-strange-timing-issues/
The only thing i can think of is a camshaft is out.
You said you have tried 3 timing lights already so it cant be that.
Every RB i play with, you can change the static timing anywhere from 10deg to 30deg and no real change in noise/note. When you add more timing it raises the idle a little (naturally) but other than that no real difference.
If you can get it to run like shit, by retarding the timing to 15deg btdc, something is wrong.
If it run like shit at 5deg btdc i would understand, but anywhere from 10deg btdc and up it should be very minimal the effect it has on a car just idling.
If your got high ron jap fuel and it doesn't ping maybe just leave it advanced.
If your keen to tinker, check the cam gears in relation to not only each other but in relation to the crank timing gear/TDC.
Yeah, I basically wanted to confirm my suspicions, the problem with buying these damned cars is you never know what's been done to them in the past. This is an RB25DET R32 conversion car and has all sorts of goodies in it, the ecu won't do diag mode tho and doesn't even have the led in the window. I'm camming it and swapping to a new turbo in about 10 days so I'll just eyeball the cam gears and hold off until the swaps and see if I can get it back to normal timing.
Thanks,
-Matt
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
