Compiling all the parts I have for sale, both spares and abandoned projects. Located in Sydney, can contact me at : cbaloglow (@) netspace.net.au.
Misc RB26 parts (cam covers, water/oil lines, sumps etc) - PM/email me what you need
Twin high mount exhaust manifolds
Single wastegate with cross over pipe between manifolds. Brand new
$1100
HKS pod filters - $50 each w/adapters
950cc injectors
Low impedance. Have 14 available
$150 each
RB26 gearbox
Both push + pull available, with or without shifter, transfer case etc.
$1200
Cusco 1/1.5 way front LSD
Suit RB26 sump. Used, good condition.
$800
Recaro Raptor interior
Complete set of front seats, rear seat and rails to bolt directly in to an R33. Seats are Recaro Raptor (have air pumps for lumbar support), rear was retrimmed by Recaro in the same material. No stains, tears or marks.
$2800
SR20 exhaust manifolds
Have two, one is one piece stainless runners, the other custom + ceramic coatered. Both place the turbo in the standard spot - internal wastegated.
$350 each
HKS 2530 - SR
Turbo has done less than 200kms. Zero carbon in exhaust housing, no shaft play etc. Can sell with an exhaust manifold + dump pipe
$1700 turbo only
HKS 2835R - internal gate T25 flange
Used, bolt on for SR20
$1500
AP 6 spot calipers
Can machine adapter to suit Skyline.
$2000
HKS 4-way Circuit suspension
Top of the line, remote reservoirs. Fully adjustable - used. Will fit both R33 + R34 GT-R.
$1200
Q45 AFM - $250
HKS DLI
Type I, new in box.
$750
Trust intercooler
Brand new, twin inlet. 600x300x76mm.
$1500
Trust 4 layer intercooler
Used, 600x135x300. Twin inlets, single 100mm outlet
$2000
HKS 280 degree cams + HKS buckets
Used, sell as a set. 10.8mm lift on both in/ex.
$1200
RB26 ARP head stud kit, new- $600
HKS ETC + EDA - R33, used $800
DBA 4000 series GTS-t rear rotors
Brand new in box, part numbers 4908SR and 4908SL.
$400
Adjustable upper arms - rear- R33/34 - $300
Solid rear cradle mounts - $100
HKS 3040 turbo kit RB25
Selling the turbo kit off my GTS-t. Custom ceramic coated low mount manifold, HKS 3040 turbo, exhaust to cat, AFM pipe. Turbo made 294rwkw @ 17psi, no wastegate.
$2,000
https://www.sau.com.au/forums/topic/72076-big-list-o-parts/
  • Replies 66
$1100
Z32 AFMS
$250 each, or $300 each with HKS pod filters + adapters. Have quite a few of the HKS filters - $50 each w/adapters.
C's short shifter
Brand new in box. RB series.
$400
950cc injectors
$150 each
RB26 gearbox
$1200
$800
$2800
Trust TD06 kit
Turbo has been reconditioned with a new, larger Garrett compressor wheel and .7 A/R housing, have a choice of 6/8/10cm rear housings. Kit has turbo, manifold and wastegate.
$2700
$350 each
HKS 2530 - SR
$1700 turbo only
$1500
HKS RB26 low-mount manifolds
Standard tubular replacement manifolds. One piece runners, exceptional welds and construction. Brand new in box.
$1500
AP 6 spot calipers
$2000
BCNR33 HKS Drag suspension
New in box, fully adjustable with valve rates to suit drag racing
$1500
$1200
Q45 AFM - $250
HKS DLI
Type I, new in box.
$750
Trust intercooler
$1500
$2000
East Bear S2 carbon bonnet - two side vents and the large vent above radiator - http://www.e-aero.jp/aeroparts/skyline/r-33/c-bon.html $1400
East Bear flat carbon bootlid - http://www.e-aero.jp/aeroparts/skyline/r-3...33/c-trank.html $900
East Bear S2 fibreglass front bar/spoiler. Clear indicators, plain style (not the one that has vents on the side) http://www.e-aero.jp/aeroparts/skyline/r-3...-33/f-bump.html $900
S2 headlight assemblies - $650
ABS plastic center grill - http://www.e-aero.jp/aeroparts/skyline/r-3...33/f-grill.html $250
Ganador mirrors R33 2 door- $450
Would prefer to work out a deal on selling the whole lot as a kit.
$1200
Nismo dash
White faced, 320km/h speedo. Suit R33, used.
$650
OS Giken twin plate clutch
Used, suit push type clutch.
$1,000
hI I WILL TAKE THE FLAT CARBON BOOLTLID IF YOU WILL SEND TO ADELAIDE FOR ME AND i WILL GIVE YOU $900 CALL ME 0415128693 ASK FOR PETE
https://www.sau.com.au/forums/topic/72076-big-list-o-parts/#findComment-1327782
$2,000
RB25 R33 GTS-t Power FC w/Hand controller
Tuned for the above turbo kit
$900
https://www.sau.com.au/forums/topic/72076-big-list-o-parts/#findComment-1328493
well are you gonna get back to ppl dude i want to buy something from you and you dont want to reply.why did yoyu go on this site to advertise?????? :headspin:
Relax mate. He is a busy man. He continually has good stuff and looks after the SAU guys. Just be patient. I think it is a bit rich you coming on here in Apr '05 and give him a spray without knowing his trader history etc... plus 8 of your 11 posts are related to trading on SAU... Sounds like getting on this site to advertise to me...
DoughBoy; I'll take one of each! free bump! :)
https://www.sau.com.au/forums/topic/72076-big-list-o-parts/#findComment-1335566
Guest
