  • Replies 66
where abouts are you located? interested in the rear rotors for 33gts-t, also the 30/40 turbo kit. Does the turbo kit come with everything ready to bolt on? how long has it been in your car? what kind of rpm does it start to boost an when is it full boost (is it relitively street friendly)? would the 294kw be about max its capable of? and was that done with standard cams in? could you send pix to [email protected]
:P
Compiling all the parts I have for sale, both spares and abandoned projects. Located in Sydney, can contact me at : cbaloglow (@) netspace.net.au.
Misc RB26 parts (cam covers, water/oil lines, sumps etc) - PM/email me what you need
Twin high mount exhaust manifolds
Single wastegate with cross over pipe between manifolds. Brand new
$1100
HKS pod filters - $50 each w/adapters
C's short shifter
Brand new in box. RB series.
$400
950cc injectors
Low impedance. Have 14 available
$150 each
RB26 gearbox
Both push + pull available, with or without shifter, transfer case etc.
$1200
Cusco 1/1.5 way front LSD
Suit RB26 sump. Used, good condition.
$800
Recaro Raptor interior
Complete set of front seats, rear seat and rails to bolt directly in to an R33. Seats are Recaro Raptor (have air pumps for lumbar support), rear was retrimmed by Recaro in the same material. No stains, tears or marks.
$2800
Trust TD06 kit
Turbo has been reconditioned with a new, larger Garrett compressor wheel and .7 A/R housing, have a choice of 6 or 8cm rear housings. Kit has turbo, manifold and wastegate.
$2700
SR20 exhaust manifolds
Have two, one is one piece stainless runners, the other custom + ceramic coatered. Both place the turbo in the standard spot - internal wastegated.
$350 each
HKS 2530 - SR
Turbo has done less than 200kms. Zero carbon in exhaust housing, no shaft play etc. Can sell with an exhaust manifold + dump pipe
$1700 turbo only
HKS 2835R - internal gate T25 flange
Used, bolt on for SR20
$1500
AP 6 spot calipers
Can machine adapter to suit Skyline.
$2000
BCNR33 HKS Drag suspension
New in box, fully adjustable with valve rates to suit drag racing
$1500
HKS 4-way Circuit suspension
Top of the line, remote reservoirs. Fully adjustable - used. Will fit both R33 + R34 GT-R.
$1200
Q45 AFM - $250
HKS DLI
Type I, new in box.
$750
Trust intercooler
Brand new, twin inlet. 600x300x76mm.
$1500
Trust 4 layer intercooler
Used, 600x135x300. Twin inlets, single 100mm outlet
$2000
HKS 280 degree cams + HKS buckets
Used, sell as a set. 10.8mm lift on both in/ex.
$1200
RB26 ARP head stud kit, new- $600
HKS ETC + EDA - R33, used $800
OS Giken twin plate clutch
Used, suit push type clutch.
$1,000
DBA 4000 series GTS-t rear rotors
Brand new in box, part numbers 4908SR and 4908SL.
$400
Adjustable upper arms - rear- R33/34 - $300
Solid rear cradle mounts - $100
HKS 3040 turbo kit RB25
Selling the turbo kit off my GTS-t. Custom ceramic coated low mount manifold, HKS 3040 turbo, exhaust to cat, AFM pipe. Turbo made 294rwkw @ 17psi, no wastegate.
$2,000
hi just interested in HKS ETC HKS 4 way circuit suspension and c's short shifter. pm me if still for sale
Chris....is a very honest person....unlike a number of others selling on this forum.
An error in address or with freight company for sure.
He has alway used TNT for all my purchases in the past....did you request a different company be used?
Phillip
guys he told me he has sent to Q45 AFM about 4 weeks ago but it still hasn't turned up. now he will not answer emails. be careful.....
I didn't realise this thread was still alive, will work my way backwards through it.
Funny you should be so alarmed, considering the goods are COD you don't really have anything at risk. As I have told you, I have sent the AFM. Aus Post are conducting an "internal investigation" over this, if I have something useful to say I will tell you. Getting sick of children on these forums, little wonder why I stay away from it.
If there is a definite problem with parts, delivery or exchange of funds I'll be onto it, but if it's some kid screaming I took his pocket money and now he can't go drifting with the other guys then stfu. Despite trading for over two years on this forum, and mainly dealing in high end parts there's yet to be a problem - unless it's a case aforementioned.
hi i was just wondering if the hks 2530 and the 2835r will bolt directly on to the rb25t? also is the hks 3040 an internally or externally wastegated turbo?
thanks pls pm me or message me at 0438453419. cheers
The 3040 is externally gated. As stated the 2530 and 2835 are internally gated and T25 flange, so not a bolt on as RB25 is T3.
StockyMcStock....
your talking out of your arse, DoughBoy would be one of the best traders on this site. I can tell you this from personal experience. I dont remember how many times i have borrowed parts from Chris for R & D over the years..
HE WONT RIP YOU OFF!!!
Send him an email and he will reply very quickly
Andrew
finally got my AFM, post office buggered up not sending me a slip in the mail.
i apologise unreservedly if my comments offended anyone or cast doubt over chris's reliability, i just wanted to say "be careful" that's all.
p.s. Chris can you pm me back with details on the AFM pinouts if you get a chance?
Not to everyone hes not. He will quickly reply to emails/pm's until he has your money then good luck getting any replies out of him afterwards.
He advertised a pair of rebuilt nismo turbos he said had been rebuilt and ready to pickup from the shop, I paid him, didnt hear from him for a few days, when I finally got a reply suddenly the workshop hadnt finished the rebuild but would send them to me when they were done.
Had photos with the serial tag still on the turbos, promised me a warranty + receipt from the workshop. A month later when I finally get my turbos they have no tags, no receipts, and NO warranty on them, and couldnt even get a reply out of the scumbag over it.
Now about 5000kms later one of my turbos have died, hes denied to speak to the workshop over it (even though he apparently knows the guy who was supposed to rebuild them) and basically said I have to deal with it.
This guy is just a lowlife piece of shit, just a warning to you all, you wont get what he advertises all the time.
And before anyone gives me the "oh well I got my parts ok/chris is a good guy" bullshit I dont give a shit, you wernt the one who got ripped off a good couple thousand, so dont even try to understand from my point of view.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
