I'm going out to see John 2moro....
Chris (doughboy) is a good guy....please keep in mind that it is in his best interests also to fix this problem midnightGTR, I will be taking up the case of at least 3 people having the same failure as me with John 2moro, and he will be given the previously stated 3 options....
  • Replies 66
Thats exactly right. Chris isn't the bad guy here, hes only one man with limited resources and his intentions are always good.
Id bet money he knew as well as I do now that these turbos were going to be useless in under 2000kms. From the way he talked about this miracle turbo shop Precision hes used them before, no doubt heard of their problems, I dont really care how much you love Chris.
WillamsF1, im in Brisbane but if you need another case against this dodgy workshop ill help however I can.
GETSET can you please write maybe a few more less choice words about your situation? I am planning on taking it up with them personally.....
your imput and problems would be good for all to hear I think....
I'm going to have to close + get this thread edited, there's too many groundless claims and assumptions that could be be damaging to SAU, the turbo business named and myself.
Quoting an employee from the turbo company, Midnight should be dealing direct with him as the problem lies with either installation, use or the actual repair on the turbos. The product sold was as described, the "problem" with the turbos has not been diagnosed. Contrary to misguided beliefs, I had no prior knowledge of the quality of the repairs nor the lifespan of the product, nor installation or running conditions. Although the "observations" by Midnight and his mechanic are quite different from the problems williamsf1 has seen with his turbos, I can neither argue for or against the work performed by the turbo company or will continue to provoke the immature and ignorant responces that have illustrated this thread. If you want to comment on how a Blitz turbo has anally penetrated you, or other creative nonsense you might want to open a thread in the wastelands area.
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
