Hey Fellas,
I've been creeping round while waiting for my line to arrive and hopefully it arrives real soon! If it gets on this months ship then it should be here on the 12th. Below are the pics of my baby. It's a bit dirty but a good amount of elbow grease should get it looking scmick!.
What do you guys reckon?
Also I've noticed taht in the engine bay near the back I have only 2 cables instead or the usual 4 of 5 that normal GTR's have? what are those cables and am i missing somthing? In the GTST's they have only 2 cables at the back so hopefully it's not a GTST --> GTR conversion. I think i'm being paranoid but you never know. Someone please enlighten me.
https://www.sau.com.au/forums/topic/72079-another-32-gtr-or-is-it/
yes they do..
Either this car chose no ABS option or was removed
I thought it was standard equipment but i guess not.
looks nice but :D
Thanks! with the engine how much would it cost to get someone to professionaly detail the bay? I would do it myself but i'm afraid of breaking somthing. :Oops:
12 more days :) heheh
nOOSE
Is it a NISMO Edition GTR? I know the NISMO ones came with no rear wiper and some other slight differences, maybe they also had no ABS - because I don't think something that aids drivers would be allowed under racing rules.
*edit*
Actually yes, I'm sure that's it.
Here's 2 of them on Prestigemotorsport, they only have the 2 wires you mentioned. Compare them to "normal" R32 GTRs that have the 5.
Nismo 1
Nismo 2
*edit*
http://www.prestigemotorsport.com.au/au/stock/details.asp?StockID=2754]Nismo 1://http://www.prestigemotorsport.com.a...ID=2754]Nismo 1
Nismo 2
So i've got the NISMO GTR.! that sounds pretty kewl. Time to search and find out the differences.
Hey Guys,
I can't find any decent information on what are the differences between nismo and non nismo. Some say no stereo, no A/C and others say it does and blah blah. Tried googling for the past 3 hours at work no luck all speculation. Does anyone actually have an idea what the differences are? Here's a few more pictures of the car if it helps to distinguish if it's a nismo.
nOOSE
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
