Hey Guys,
Will be putting a new system in my R33 pretty soon and i'm not sure if my battery will be up to scratch. I'm still running the original Japanese battery, which appears it may be on its way out after spending months sitting doing nothing. It's ok and the car starts, but as I said, its the original... :uh-huh:
I'll be adding 2 amps to my system. a Clarion 400W and a Sony 222W.
I was wondering if anyone could offer advice on whether I should change my battery and if so, what type/brand of battery should I use to effectively run this system?
https://www.sau.com.au/forums/topic/7208-new-battery-to-run-2-amps/
My stock battery seems to go fine running two amps, even when the volume is way up and I have headlights on.
If you have any doubts, install a capacitor (about $150-$300) for your amps.
But I reckon you'll be fine. I'd only change if you're not happy with the results...
Blitz33
-I think the oddyssey 1000 battery put out about 380 CCA.
They are a good battery just dont let them go flat, ie rarely run your system without the engine runing, as they die when they are drained of most of there power. They dont behave like a normal lead acid battery.
That oddyssey sounds like a monster battery, but also a monster price too...
I reckon any standard heavy duty battery of the right rating will do the trick... people run 2 amps + much more off the one battery with no probs.
Amps draw less and less power these days as well to output the same amount of wattage. More efficient components.
Guest mooks66
those amps wouldnt be pulling too much electrical draw from your system. you should be fine
just get a nice healthy 4guage power for red and black
and also upgrade your battery's ground to 4guage and also your alternator wiring to 4guage and the stocker batter will cope a heck of a lot better.
that done, your set to go
4guage into a distribution block and then 2x8 guage to the amps and your all done.
good luck
in any serious sretu i wouldnt go past and OPTIMA yellowtop deep cycle battery
950CCA 95A regular cycle and its a 95AH cell
where as the highest oddesey has to offer is a 65ah cell and the standard battery in skilines id a 45ah cell
if doing a big install the ah rating is more iportant than the CCA
and a high regular cycle can only help things along
dont forget a 100w RMS X2 amp will draw about 300W - 400W from your battery which works out to be about 30 A
im running 600w worth of amp and it draws almost 1000w from my electrical system
im using and optima yellow top and i get no dimming of the lights with all healights on
bottom line is the bigger the battery the better
I'm suprised nobody has mentioned alternators at all in this discussion.
How did you go fitting the Optima in the Skyline?
I am looking at a new battery for my 33 GTR as the factory one is tiny and rooted. I haven't taken all the bracing out yet so haven't sized up what I've got to work with but the options for the battery seem very limited by the size of battery you can fit in.
At the moment I am thinking of goind with the Odyssey 1000, but would much prefer the Optima/Exide if at all possible.
there is plenty of room in the back of the R33 GTR for a replacement battery, i am running the odyssey 1000 in mine, just had to make up a custom bracket to hold it down, and a little L bracket to make sure the battery doesn't move.. there is plenty of height and width available..
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
