Has any one pulled the front bar of there Stagea?
I’m planing to pull mine off to fit some mesh in front of the intercooler, to hide it a bit and protect it from stone chips but can see my self spending a day crawling around trying to find all the attachment points and get it off without busting any clips. :)
Dose any one have any tips, photos of a Stagea without a bar, the back surface of a bar off the car or can tell me where all the attachment points are.
https://www.sau.com.au/forums/topic/72083-removing-front-bar/
