hi,
as i advised earlier my turbo is smokingup. so im trying to upgrade without wasting the moment. so GT28 is probably the way to go! will spool up at about 3k? i guess.
sydneykid advised me that i would achieve around 220-240rwkw once the mods are done.
i have a trust cooler, full 3-4 inch race system, HKS pod and bleed valve set to 10PSI, got 170rwkw.
so any help would be great!!
thank you all
ron
Ron, sydneykid has most likely forgotten more about cars than I know.
I think that as long as the turbo meets your requirements go for it.
The Garret ball bearing series are by all reports, a very reliable turbo.
The main reason I was asking the questions is that you need to consider all things. It definately would be no good getting a turbo that has too much lag for your liking, or will need upgrading in the near future because you want more power. That is of course unless you don't care about the added expense in the future. You may even be better going a highflow stock turbo.
Personally I am thinking along the lines of either the GT28 or GT30 for my future upgrade, still not too sure (haven't got the cash right now either, so no hurry)
Steve
edit: you may want to think about some type of management at the same time - not too sure how the GT28 flows compared to the stock turbo.
riggaP.
10deg difference is about 15-25kW, plus the engine is less likely to detonate. It's a relatively cheap way to maximise your horsepower, and reduce strain on the engine.
Go for big FMIC and CAI, it can't hurt.
See'ya:burnout:
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
