cheers for those prices. Although they claim to be a 'bolt-on' kit, is it still quite a time consuming job? I realise it will depend on the workshop etc., but are we talking 2 hours, a day...longer??
i say if u have a weekend free, and the right tools you could do it :D it many take you 2days :) but it will be free. You will be amazed what you can do when you put your mind to it ;)
the basic tools you would need i would say be a good socket set, plus jack and car stands, and maybe 2friends to help you out :)
The beauty of trust turbos is that they come on boost quickly, unlike 'old school' bush bearing turbos.
Added to the quick spool is that they work better at high boost, in that they dont wear as quickly as BB turbos.
Most HKS BB turbos are recommended by HKS to run between only 0.9 and 1.1 bar according to the goodsmaster catalogue. They do of course work well at alot higher boost, but the longevity is effected (according to a Jap mechanic I had a chat with once)
EDIT: 2xGTRS on GTR = LAG, big time.
The Plain bearing T517Z's are far less reliable than the GT style ball bearing turbos.
Plain bearings have far higher friction than ball bearing = lots more heat.
The Trust turbos are not water cooled = more heat.
More heat = more wear.
More wear = less time before failure.
On top of that the ball bearing turbos response time is faster over the exact same plain bearing design.
Also the lower the boost pressure the better. If I can acheive the same horsepower at a lower boost why wouldn't I go that way. Longevity is effected on everything with higher boost not just your turbo, this is true of any turbo including the trust units. Boost = heat.
Having said that the guys at Trust have chosen good matches of housings, compressors and turbines despite the fact that they are done on the cheap, they don't pass on the saving to you though.
I understand all the points you have made, and they do apply 'theoretically' on their own, but once applied to the context of the posts above, they start to fall apart...
Where did you get that info from. I have spoken to a couple of prominant tuners in SA that both SWEAR the trust turbos are more reliable than BB. I have seen trust turbos that have had alot of abuse without any reliability problems. I have seen a BB turbos that have shown signs of wear (CHRA getting loose) after 10,000kms.
This may be true if you were comparing two BB turbos or two bush bearing turbos one with and one without water cooling, but otherwise you just arent comparing apples and apples.
The bush bearing is designed to run without water cooling, the BB is designed to run with. Agreed if you were to water cool a bush bearing it MAY last longer, but you cannot compare the life of the two without actually doing tests.
The 'exact' same bearing design???? They arent the exact same bearing design.
Yes BB design works well, but from what I have seen, bush bearings have come a long way. If you had the same spec turbo and used two different CHRAs, you may have a valid point - but at the end of the day, they arent the same spec. The GTSS works well, so does the T517
Very true, but you also need to take into account MANY other factors, such as the compressor efficiency, etc, etc, etc. But still, if a turbo is 'limited' in its ability to make boost (due to longevity reasons) why wouldnt you buy a turbo that has extra potential, ie, can be boosted higher without having to worry about the turbo needing to be rebuilt.
If you had a choice of two turbos, both flowing the same amount a 1 bar whilst being 80% efficient. Both of the turbos will flow the same amount of power at 2 bar, with 75% efficiency, but one will last 5000kms, the other 20000kms - which would you choose. Of course the one that is capable of producing more power with minimal reliability issues when compare to one that WILL have reliability issues.
Hmm, when you consider that you can now buy a performance turbo, that lasts well, and works very well for under 3k bolt on kit, all gaskets, adaptors, hoses, clamps, lines etc, I dont think they are bad at all. Especially when compared to what if available for a few dollars less in generic turbo form that just doesnt give anywhere near the same performance. After all the heart of a turbo charged car is the turbo - a good one will keep the smile on your face every time you drive the car.
Once you take into account duty, gst, broker fees and shipping, importing a HKS GTSS turbo kit is more expensive than buying a trust T517Z kit that is being retailed in australia for under 5K.
GT turbos are good, no denying it, you do need to keep the boost down if you want to get a long life from them, they are FAR more expensive to rebuild than bush bearing. As long as you buy a performance setup for the style of driving you want (street, drag, drift etc) you will be miles ahead of someone running a generic turbo.
GTSS and T517Z are both excellent turbos, just dont rule out the T517Z because they have bush bearing instead of BB. They are bloody awesome turbos.
they dont compare, they are cheap generic turbos, not performance turbos.  Good if you want a cheap upgrade, not so good if you want to realise the best from your car.
Gee Steve, not sure that the folks at Garrett would like their Gt 25-30 referred to as cheap generic. Particularly given the close link Garret has to other turbo suppliers...
My post was meant to refer to the pricing and the inclusions of all the fiddly bits you need to properly bolts the things up.
IMHO Garrett 25-30's are a very good thing on an RB26.
Well, we need to get something straight, HKS make GT2530, garrett dont - places like Horsepower in a box seem to be jumping on the HKS bandwagon by naming their turbos the same.
A garret 25-30 is not do the same as a HKS 2530 - PERIOD. The combination of wheels and turbine/compressor housings is ONLY sold by HKS. they started naming them, then others do the same or tell you they can do the same - its just not possible unless they buy the parts from HKS and put them together, which is more expensive than just buying it complete from HKS.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
