Ok peeps ..... Pauls been on my case for a while now to get rid of these out of my garage because as you all know my baby is now sporting his hand me downs ..... so if anyone would like my hand me downs please get in contact with me.
4 x Roh 17" Adrenline Rims in reasonably good condition - theres a mark on the rear one - its not huge - otherwise they are like new. They are without tyres ..... well there's tyres on them but lets just say they arent much use to anybody and i'll get them stripped off before I hand them over ..... unless you want them.
Most people know what my car looks like on them - and unless you've had your head in the sand for the past 5 years you should be familiar with what these mags look like.
$650 ONO
Cheers
Lauren
https://www.sau.com.au/forums/topic/72203-fs-perth-only-roh-rims-17in/
can u get racks for a line?
please say yes cos the boards are driving me maaaadddd!!!!
we looked everywhere but we can only find soft ones and they dont fit a two door unless its a hatch?
Yes you can.There was a thread about them a while ago. Search this forum for roof racks. I'm sure you find something :(
Now back to the topic please ;)
Interested, If no one snags them by tonight I'll chat with you or Mr Paul at the commitee meeting tonight. (yeah I know I need to get rid of my stockies)
mikey theres 2 sets of rims at garage gav that might interest you the ones on cherry red now and the ones on my avatar both sets need lil tlc
if i could get rid of one of these sets i might be interested niz
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
