i know this sounds like a stupid question but how do you adjust and check the timing on RB engines
like i know that the CAS is what adjusts it and stuff but how do i check the timing
i have a timing light that connects to the leads usually, and you all know that RBs dont have leads so how do i check the timing
and where do i connect the timiing light too ect.....
all help is appreciated
thanks in advance
matt
https://www.sau.com.au/forums/topic/72217-how-do-you-adjust-the-timing/
either:
a) at the back of the coil pack loom there is a white wire that you are supposed to use for timing. hook the timing light over it as if it were a spark plug lead.
B) take out coilpack number one and take off the the rubber bit at the bottom of the coilpack that goes over the spark plug, then put a lead from the spark plug to the bottom of the coilpack and hook your timing light up to that...
there is a black loop at the back of the cam cover that you use insted of the spark plug leads.
be careful reading the timing as there is sevral marks on the cover below the crankshaft wheel that line up with the timing belt mark.
if unsure just take it to a midas and they will ajust it to whatever you want for $15 bux
Not sure about skylines....
Normally u connect the CAS gun to a spark lead.
Aim the light @ the timing adjustgment screw (look around the timing belt bottom of engine area???)
and move the line to advance or unadvance timing...
in the first post i already know how to use and adjust timing just not with coil on plug configeration
and yes i know how to move the CAS to advance and retard the timong have already done that to get the car firing for the first time last night
but i dont know where the sweet spot is thats why i need to know how to!!!!!!!!!!
thanks anyway
no you see that is my problem if you know where forster is you know this is a problem mechanics here are old and basically dont want to touch it unless they have like a greggery's workshop manual for one if you know what i mean (ie.. they wont touch the imports)
thats why this car has been built by me and a mate in the back yard form the ground up
as for the black loop where bouts on the cam cover is it exactley as i have seen no loop on the loom what so ever
and by cam cover are you talkin bout taper covers??? and is the loop supposed to be before or after the ignighter???
matt
either:
:D
This is the safest method. But you don't necessarily need to remove the coil pack's boot to get it to work, in fact leaving the boot in place helps keep the plug lead in contact with the terminal.
Base timing at idle is 15 BTDC.
OK SOO... I CUT THE END OFF A LEAD, PLUG ON CYLINDER ONE SPARKPLUG AND JAM THE OTHER END IN THE COIL PACK ????? IS THIS CORRECT
pretty much
but you should need to cut the lead. i have never cu the leads. just used them as is... :(
You'll be right. have a play... cant really go wrong.. just dont get sparked by the coilpack :( and dont let it zap the motor... although there is no harm in doing so. im sure its not good for it :(
i have a rb20det in a silvia what is the procedure with the timing
ie....
i have the service manual it says to turn the idle screw on the computer all the way down then disconnect the AAC ( ? ) bla bla bla...
can someone post a step by step guide and disregard the "where to put the timing light" ill sort that out??
remind you that i have a rb20 and at the moment have done nothing at all to the timing what so ever just the way that we put the engine and put a new timing belt on!!!!!!!
ok here is my trouble
the manual says that BTDC timing is 15 degrees at 650 rpm thats with air con on
my truoble is that because i have fitted into silvia have removed air con to fit the thermo fans and custom manifold wastegate bla bla...
what do i do the car wont idle lower cuz there is no air con
so what is BTDC degrees at what RPM with out air con????
I've never set timing with A/C on. I think the only time you load an engine is in an auto (stuff it in 'D').
So in short, the answer to your question is 15 BTDC @ 650 rpm
Also, no need to cut the plug lead. Mabe just need to slip the "cap" end of the lead back a bit to expose the terminal better.
but i dont have an auto so do i set the timing just at the normal idle??
plus my tacho is not correct has not been converted for the rb so im blind at the moment just cant afford to get another thing wrong thats all!!
You don't have to have the engine idling exactly 650 - I doubt you could ever make it do that. I know that reading the handset on my Wolf 3D, the revs can vary by as much as 50 rpm aroung the idle point.
If the engine sounds like it's idling at somewhere near the right revs, then you can set the timing. As long as it's not racing or anything. Usually, changing the timing a bit can often change the idle revs anyway, so you'd end up chasing your tail - idling too fast, change timing, idling too slow, change timing...
  • 2 months later...
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
