FS: VDO Dayton MS 4200 RS ( http://www.vdodayton.com/ ) in Excellent Condition. Currently still in the car functioning perfectly except no way to test the navigation because the map CD has not yet been unlocked so suitable for anywhere in Aust. :) (you pay per city I believe)
4x40W
Intelligent destination input
POI browser
Quick access street search
ZIP code entry
Comprehensive icon and voice guidance
21 Voices (male or female) in 9 languages
High speed processor system
Adaptable display brightness
Trip computer
Digital sound processor
7 Sound presets
Speed dependant volume control
Digital cd changer control
Detachable flip down front
Security code able
Comes with language change CD and Whereis Navigation CD *NEVER BEEN USED OR REGISTERED* Original box and manual.
Postage at buyer’s expense deliverable in SE Melbourne
$1000ono
https://www.sau.com.au/forums/topic/72218-fs-vdo-dayton-ms-4200-rs/
hey budy would you consider a swap for a top of the range alpine HU? i have a Alpine CDA-7998R Bass Engine PRO CD/MP3 Player/Tuner with all the fruit, only had it 3 months and it is absolutely killer, just wanted to get some nav in the car that all.
let me know... will pay the postage :D
Yes I will consider it just checking specs and ability to integrate with the rest of my system which I am pretty sure it will perfectly ;) I'll put up a pic of the actual unit tonight, could you send me a pic of the 7998 - [email protected]
Basically you register it and they give you a code that you put into the HU and it decodes the maps that you have paid for (as with any GPS system it's the maps that cost the $$$ the actual GPS positioning is free). The unit comes with the manual and discs so that won't be a problem for you. It has some really cool features like the trip comp, speed limiter (good to set for when others drive your car :( ) etc. The Alpine unit will fit into my plans very nicely so if you like the VDO unit and approve of it's condition (which is excellent) I'll have it professionally (Stylyn or Tower Audio) removed and ready to send to you registered and insured.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
