Reluctant sale – Nissan Skyline R32 GTS4 89 (Sep)
imported to Australia Feb 05
complianced by a registered automotive workshop
AWD
103,000 kms
White coupe
4 sp Auto
Registered to 8/05 (mounted plates OMX61)
3.5in exhaust with 5in tip
Stock 16in rims with new 225/50 tyres
Have only performed maintenance since arrival - no mods (running 10psi as is):
- full major service
- new exhaust pipe
- L & R front strut bar bushes
- new feed pipe to turbo
- Bendix front & rear brakes pad
- Machined rotors x 4
(receipts for all work done)
Genuine reason for sale – have been truly happy with this car, but quite simply too cash strapped to afford the insurance payments and spend the money on her that a car like this deserves.
Selling as is. Will be totally upfront regarding her condition, which isn’t perfect, but honestly you wouldn’t need to put much into this car to have it performing & looking awesome.
Interior passenger air vent removed during transit from Japan; have new clarion stereo & speakers but haven’t had time to install – a few other minor marks inside but otherwise very tidy
Some minor paint scuffs here & there (mostly transit joys once again) nothing major, just bits & pieces. It’s all obvious as an inspection would reveal.
Can provide contact for mechanic who has done all work since arrival – mechanically excellent (comments were ‘goes & handles like a cut snake). Have performed most of the maintenance needed and some repairs; front cv’s boots will need replacing soon (quoted around $200). This workshop has also quote for full re-spray at $2000.
This is a top little car that needs some spit and polish, but all who have seen/been driven in her were very impressed. Inspections from genuin buyers welcome – test drives for serious buyers only.
Selling this car a lot less then market value; will accept best offer over $12,500 - but quite simply won’t sell for less, so don’t ask.
Located in Brisbane
Contact Paula or Chris:
[email protected]
Phone: 041 091 3537
https://www.sau.com.au/forums/topic/72228-r32-gts4-coupe/
  • 2 months later...
  • 4 months later...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
