hey hows it going, atm i am on a search for a R33 gts-s 2 door manual, as it is going to be done up as a show car.
I have a coupel of questions that i need anyone to help me with pls
Ive done alot of searching and check out heaps of boot displays all looking awsome.
1. if i airbrush a sub woofer, would it defect the sub woofers performance in anyway or muffle its sounds???
2. is there enough room under pass seat for a PS2 to sit?
3. Where can i get a 12v power suplly for the PS2 to run in car
4. anyone got measurements of the boots
Im looking at running to 12inch kicker square subs, 2 1000wtts (600r), alpine deck, tv monitor above deck, slpine 6 1/2 inch splits in fron, same in back running off a 800w alpine deck, subs are air brushed and there are words in there sum where but cant explain all of it as i need the idea to be MINE hahahaha
any help would eb great thanks
AHHH 33
https://www.sau.com.au/forums/topic/72259-a-few-questions-and-stuff/
I would reccomend looking at other amplifiers than Alpine, as there is a lot of quality out there... namely the US brands: Boston, Phoenix Gold, just to name a couple i have dealt with.
PS2 will fit under the passanger seat, all you need to power up is a transformer 12VDC-240AC (available from most Auto shops). Alternatively you could modify the PS2 itself and run 12VDC directly to the PCB in the PS2 if you know what you are doing.
Personally, i would highly recommend XBOX due to its inbuilt HDD, and capabilitys as a Media Centre, once it has a modchip installed. this will help greatly when driving on bumpy roads! You will also save money on having to buy and extra DVD player for the TV screen, unless your deck is DVD capable.
Dont forget about cabling and sound deadening...
I just recenlty spent $1500 on cabling, sound deadening and optima battery. No point getting compettition components without installing it properly IMHO.
Also i wouldnt worry so much on getting top end speakers for the parcel shelf, as their main purpose is primarily for refill, and SQ isnt really a main factor when you have a quality front stage!
If you are interested in some prices on a high end setup, drop me a PM, or add me to msn and i should be able to help you out!
PM me if you want my msn details, and ill help you out as much as i can.
no airbrushing won't effect, the performance, i spose theoretically it'll make the cone slightly heavier, but it will be really really negligable only thing u wanna make sure of is that if u have any cone flew which might cause the paint surface of sumthin to crack or what effect the crazy vibrations will have on the artwork.....
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
