Hi peoples,
just got a question relating to any things to check or replace when a car hasnt been running for a few months. Is there anything other than battery/engine oil/filter/fuel filter/water/coolant to check over??
eg the rust on the brake discs, does that just sand off when used again? Brakes? Fuel system/tank?
It was in good order just hasnt even been cranked for a while. rb20det
advice appreciated :(
https://www.sau.com.au/forums/topic/72272-common-problems-car-garaged-for-ages/
Hi peoples,
advice appreciated :D
Hi inissane,
how long exactly did you do in jail?
Seems that you've got the main stuff covered inissane.
Don't worry about the rust on the discs, this is only surface stuff, and a gentle/safe drive will have them sorted and looking normal again.
Get your AirCon cranking over too...a must!! (if u have one?)
Someone mentioned fuel??....this will be stale, don't panic, use it!
Once all that petrol is gone, if you really are concerned, change your fuel filter and fill up!!
Are your tyres square yet?
So, how long did you say you were in for?
Anyways, let us know how you go!!!! :wassup:
lol Mark.....pleaded inissane and got off on 3 months!! :wassup: (jokes)
havent needed to drive it daily for a while so its stationary and getting tweaked.....slowly
but yeh changed the fuel filter already so might put the old one on and use a couple of tanks of fuel then put the new one back on I guess...
check tyre pressure...anything else likely to corrode/get stale?
PS- whats the deal with the air con? thanks again
About the most important thing when storing or not using car for long period, is brake fluid. For preference,you should bleed the system right through, so that there is NEW fluid right through the system. Reason ? Brake fluid absorbs moistute, which is why you should renew it every 12 or 18 months anyhow. Moisture lowers the boiling point, and makes brake fade easier. When stored, the moisture can cause rings of corrosion adjacent to seals [especially in wheel slave cylinders] and later cause seal leakage, and occasionally fairly sudden brake failure. This does'nt normally happen when car being used [even with old fluid] as the pistons keep being moved, preventing any corrosion build-up.
LOL---Glad ur the sort of bloke who can take a joke...that's ace.
OK...Air-con deal......well it's quite simple actually.
Any compressor likes to be used, like all sealed and rotating mechanical devices.
The seals and bearings in these units that make them work the way they do tend to be like girls,........... ignore them and hey get pissed off very quickly.
Switch on the compressor once or twice a week (at least for a few minutes) so the seals stay fresh and the bearings stay lubricated.
What can happen, and I've seen this, is that the compressor gets turned on once in a blue moon and then suddenly seizes, (expensive trick that one, makes a great sound too as it lets go!) Drive belts break, and all sorts of wonderful things happen, simply put.
Do you get the drift?
Anyways, hope this helps a tad.
and..........I hope your bum doesn't hurt too much. :wassup:
There is actually a word for this.....when a fluid/liquid wants to absorb water.
Is it Hydroscopic?
Good and important thread!!
  • 3 years later...
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
