*REPOST, AS SALE FELL THROUGH*
Turbo Package suit RB20, RB25, RB30, SR20 & Tough CA18.
Turbo Package Consists Of:
A Percision T04e, (with a T/3 Flange,)
Turbo Bag
40mm Waste Gate,
Braiden lines,
Gaskets, Bolts, Chrome fittings and V-Band fitting
Also includes Hks Pod Filter.
This turbo package is capable of making 300rwkw on only 14 psi. The turbo have steel front and back wheels and are brand new are rated at 550hp. it is also 360 thrust bearing The package comes with all of the necessary fittings to make it an easy fit to any car, there is no manifold included, was bought from this forum and never put on, now selling and using cash for other investment.
PRICE DROP $800 FIRM NEED TO SELL ASAP
PM or call 0400261099
if this bolt on type, where are u gonna attach the wastegate? surely ur gonna have to make a new manifold are u not? jus wandering...the turbo package is cheap, jus wandering how ur gonna fit it wif no manifold included
You have 3 options
1. Weld it to the rear housing.
2. Weld it to the factory manifold
3. Buy a new manifold with the wategate pipe ( I can refer you to someone who sells them, Highmount ones $500+ I think)
Rs,
I am wondering this turbo looks alot like the turbos you can buy of ebay the wheels are the same the red dot is the same the blue plate is the same. Who did you buy this turbo of and how come you are selling at a cheap price. Who actually makes percision turbos do they have website which we can look up because ive done alot of searching and cant find anything about them that would probaly put alot of peoples minds to ease if we can find out more about this turbo otherwise I think you might struggle to sell this item as not many people can trust it.
These are all honest qs please dont take offence to them as an answer would put my mind at rest.
I bought it "drewcrome" off this forum,
http://www.skylinesaustralia.com/forums/sh...ghlight=package
I im selling the kit cos I need the money for somethin else. He assured me that this is not a cheap china turbo and was fully inspected by a performance shop in Brisbane before he bought it.
Still for sale and looking for $850
Rs,
what sort of car where you going to put this turbo on beacuse why would you buy a turbo around may when you where trying to sell your car around xmas last year
Are you stalking????????? lol
It was bought to put on my Skyline, and yes it was for sale around DEC/JAN but didnt sell with little interest, so i bought the turbo as i do like to spend money, but however now i need the money for another investment and am quite happy with the power increase the PFC gave me, i have decided not to put the turbo on.
PS, i have green eyes and like seafood........hahaha
Rs,
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
