Hi All
I just fitted a ARC FMIC Kit yesterday and the power feels more smoother but no as great...the kit was second hand, do you think that there could be a hole in the cooler or hosing, or do you think its just my imagination...any help would be great...and yes ive double checked the clamps and they are super tight....cheers
https://www.sau.com.au/forums/topic/72288-intercooler-question/
Hi All
I've had a small hole in my cooler before. You definitely know when you have a hole in that you can definitely hear it even off boost.
not vacumm but boost seems a little low (still at stock) but feels not a hard to kick in...i didnt know if this happened when fitting a fmic or not
Whats your vacuum at idle? should be around -500 ( reading of the PFC hand controller on mine)
Umm I am definitely no expert... but it just sounds like the bit of extra lag you get from fitting a FMIC and all that piping compared to the stockie???? Normal I thought - hence why u normally combine the FMIC with mods like a full turbo back 3" exhaust and a bit of extra boost etc to balance out the lag... the FMIC istself doesnt do much for performance - but creates a cooler environment to allow you to fit more mods and up the boost with less risk
Personally I wouldnt do a FMIC if you werent modding up - but then again thats just base on other reading in here - so i could have it completely wrong :rolleyes:
i will check the vacumm next time i start up...brazen cheers , but i have a 3inch system
Yeah - but whatever mods you have - at the point you install a FMIC you will get an increase in lag over what u had before the FMIC... did u have a FMIC before and just swapped to a Blitz system - or go from stock sidemount to FMIC?
Yup - thats all it is - you've introduced a bit more lag with the extra length of intercooler pipe - so it'll feel a bit more sluggish - although your peak performance probably hasnt dropped - just changed your curve.
The FMIC just now will allow you to do a few more adventurous things to up your power and push it power back down the curve a bit - whereas pushing a bit more with the stock cooler would start getting risky further down the track... talk to your tuner... but the FMIC and maybe a couple of extra bits and pieces should now let you up your boost if you so wish or do more hardware mods. It wont take much now to get that lag out of the way and make the car FEEL fast again :(
if the cars stalling, from my experience, the fmic should have nothing to do with this saga..
perhaps, check with your tuner about these few things..
- b.o.v could be leaking,
- fuel pump maybe earthing
- if its a series 1, rb25det, check you coil packs & the ignitor pack above the #6 coil pack
- crank angle sensor maybe ****ed, & might need replacing
* my car did this, i though the b.o.v maybe leaking, but that wouldnt cause your stall
- my cars crank angle sensor was not sending the right signal, & the ignitor pack was ****ed as well, ive replaced both c.a.s & the ignitor pack ( as we speak its in shop) & the mech said thats my problem, maybe yours too...these are just a thought...
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
