Hi All
I just fitted a ARC FMIC Kit yesterday and the power feels more smoother but no as great...the kit was second hand, do you think that there could be a hole in the cooler or hosing, or do you think its just my imagination...any help would be great...and yes ive double checked the clamps and they are super tight....cheers
https://www.sau.com.au/forums/topic/72288-intercooler-question/
Hi All
I've had a small hole in my cooler before. You definitely know when you have a hole in that you can definitely hear it even off boost.
not vacumm but boost seems a little low (still at stock) but feels not a hard to kick in...i didnt know if this happened when fitting a fmic or not
Whats your vacuum at idle? should be around -500 ( reading of the PFC hand controller on mine)
Umm I am definitely no expert... but it just sounds like the bit of extra lag you get from fitting a FMIC and all that piping compared to the stockie???? Normal I thought - hence why u normally combine the FMIC with mods like a full turbo back 3" exhaust and a bit of extra boost etc to balance out the lag... the FMIC istself doesnt do much for performance - but creates a cooler environment to allow you to fit more mods and up the boost with less risk
Personally I wouldnt do a FMIC if you werent modding up - but then again thats just base on other reading in here - so i could have it completely wrong :rolleyes:
i will check the vacumm next time i start up...brazen cheers , but i have a 3inch system
Yeah - but whatever mods you have - at the point you install a FMIC you will get an increase in lag over what u had before the FMIC... did u have a FMIC before and just swapped to a Blitz system - or go from stock sidemount to FMIC?
Yup - thats all it is - you've introduced a bit more lag with the extra length of intercooler pipe - so it'll feel a bit more sluggish - although your peak performance probably hasnt dropped - just changed your curve.
The FMIC just now will allow you to do a few more adventurous things to up your power and push it power back down the curve a bit - whereas pushing a bit more with the stock cooler would start getting risky further down the track... talk to your tuner... but the FMIC and maybe a couple of extra bits and pieces should now let you up your boost if you so wish or do more hardware mods. It wont take much now to get that lag out of the way and make the car FEEL fast again :(
if the cars stalling, from my experience, the fmic should have nothing to do with this saga..
perhaps, check with your tuner about these few things..
- b.o.v could be leaking,
- fuel pump maybe earthing
- if its a series 1, rb25det, check you coil packs & the ignitor pack above the #6 coil pack
- crank angle sensor maybe ****ed, & might need replacing
* my car did this, i though the b.o.v maybe leaking, but that wouldnt cause your stall
- my cars crank angle sensor was not sending the right signal, & the ignitor pack was ****ed as well, ive replaced both c.a.s & the ignitor pack ( as we speak its in shop) & the mech said thats my problem, maybe yours too...these are just a thought...
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
