  • Replies 42
and its still stuggling to get any decent power :rofl:
Its so hard to listen to these whale songs... gives me a headache.
*sigh*
More power than you Mr extra 1/2 litre :)
Don't believe me? Come on down and SHOW me biaaaaatch :Bang:
Nengun reakons next Friday for my coils, so It'll be touch and go if I can beat a stocker (I'm loving 1/2 throttle).
Also, my car may not even run as it looks like we'll have WELL over our limit of cars wanting a run... and like I said I'm there every f$%^&ng week.
camma and other travlers get spots reserved of course.
Have some larger V8's comming for fun :rofl:
Well, to be honest I don't know... but Squealy's GTR put out 260 rwkws on a cranky day.
My car will splutter its way to 190ish rwkws, although it still can't do it on the road without new coils (soon as its boosts over 12 -14 psi, it dies... Nenguns have had a hold up)
ARM85 may make 120 rwkws if he is lucky... he he he
Ummm... there is a GT30 equiped VL turbo I'd expect would make some power. Plus a lot of the usual V8's and stuff (out here everyone loves their commonwores).. That said last night I had a real struggle getting past a falcon (EB-ED 1993ish)... it had some balls :D
Hopeing that Stolly will bring his R33 GTR, apparently is got some big nuts.
Top day Anthony, thanks for organising it. I rattled off 184rwkw from the 4 cylinder but with a few boost problem sorted I should be able to squeeze a little more out of it. It was good to meet a couple of the SAU lads. See you at the next one!
What were some of the other results that I missed?
Thanks for making the trip Camma!
The standout was the Maroon VL Turbo with the huge GT30 hi mount. It had to be re straped three times :burnout: and made 1333.8 NM of tourque... and 270kws :P
Ummm, other than that there were some standout shi%^ers, including the R33 running nos hacking its way to 120kws, the Yellow NAT VL which claimed 200rwkw prior to the day, and rolled 141.
Had a stocker VX S pac comp at the end, with 114 and 122 kws.
Fun day though, next one will be a lot bigger - with promo girls and stuff. Will keep you all posted on that one.
No no no gents
120rwkws - turbo with nos shot. Its sounded like a sick dog though, claimed there was more in it and HP didn't know how to use a dyno.
It sounded like it was missing, backfiring and running rich and lean all at the same time.
Yesterday another Skyline who wouldn't run on the day came in (N/A), young guy.
Ran 113rwkws - which is pretty good I thought, nice and smooth too.. Told him he should've entered, really neat car too.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
