One thing after another at the moment.
Now when the car is hot (as in I've been giving it a bit over say 15 minutes)
It breaks down like a coil pack or plug.
My theory was that the power transistor/ignitor plug thingy was getting hot and the plug connector to it was coming lose cos its clip is broken, but I carefully wired it together and the sucker still does it. Is it common for coil packs to only do it when hot or Igniters??
https://www.sau.com.au/forums/topic/72298-breaking-down-only-when-hot/
its a common problem on the 300zx with the ignitor
engien heats up, solder that holds a wire in the ignitor melts causing to lose connection and car cuts out. let the engine cool and the solder re-forms and the connection is again made
check out www.aus300zx.com for more info, or get a new ignitor
cheers,
Warren.
I have been having the same type of troubles and Nissan cant help me. It has something to do with the electronics but not the coil pack or plugs as i have changed both and the problems still persist.
