Please can anyone help? I own a 97 Skyline GTR that is running on 5 cylinders most of the time. I have taken the car to Nissan and they have replaced the plugs and number two cylinder coil pack, and the problem is still there. Nissan can’t find the problem and they can’t find anyone that will look at the car either. I think it has something to do with the electronics but not sure. It runs like crap nearly all the time now, but if I put it under a little boost while its cold it runs normal till it warms up then runs crap again. If anyone has any ideas on how to help it would be greatly appreciated. Cheers
https://www.sau.com.au/forums/topic/72302-gtr-running-troubles/
Rotate the *new* coil pack and see if the missing cylinder moves. If it does they've replaced the wrong one.
Alternatively pull the plugs and see which is fouled.
Could be any number of things - plugs incorrectly gapped, igniter (if R33 have them vs R34 with built in igniter into coil), dodgy coil-to-igniter loom...
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
