May Monthly Dinner - 26/5/2005 - The Great Northern - Pacific Hwy Chatswood
  • Replies 222
If I had my way, we would go to the Thai near Duncan and Kel's place.:wassup:
Good parking and cheap, with a bottle shop next door with the super chiller:cheers:
I SECOND THAT !!!
I think thai orchid should be the default location if we cant make up our minds....
plus you also get hours of entertainment watching duncan try and work the "super chiller" :cheers::(
Thai Orchard is good,  but how about a something different for a change?
Heh heh yeah, we eat that stuff at least once a week.
My point was really about mixing it up, maybe going south or west for a change?
I'm happy to try somewhere other than northish. it's just that that's the areas that we know restaurants so we tend to recomend places there.
I'll have a think for somewhere southish and post it up.
The only places I know of South are around Brighton - probably *not* the best spot for us!
I'll ask around and see what else I can find.
There's Big John's in San Souci (on Rocky Point Rd). Big and cheap Italian food (mains pasta dishes are huge and only cost $15 or so, seafood is their specialty). If we make a fairly large booking (say 20 or so) we should be fine. Last time our group of 8 had a booking and still had to wait an hour :O However that was on a Saturday and they had a big gorup booking which had priority.
Parking isn't the best as it's street parking but the area is fairly safe.
There's Big John's in San Souci (on Rocky Point Rd). Big and cheap Italian food (mains pasta dishes are huge and only cost $15 or so, seafood is their specialty). If we make a fairly large booking (say 20 or so) we should be fine. Last time our group of 8 had a booking and still had to wait an hour :( However that was on a Saturday and they had a big gorup booking which had priority.
haha I was just about to post up Big Johns when I read kels post about brighton.....
Italian seafood restaurant....and yes the dishes there are HUGE !!
went there for a mates bday and we had like 8 people....and we couldnt finish the seafood platter for TWO......
Like cereal mentioned the area is pretty safe....plenty of spots on the side street around the corner..near the KFC.....I got there early and manage to score a spot right in front of the restaurant :O
and omg..the bruchetta(sp?) there is like half a loaf of bread....
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
