May Monthly Dinner - 26/5/2005 - The Great Northern - Pacific Hwy Chatswood
Good question NewTattoo... is there parking close by?
Kel.. I was attacked about 2 years ago for never doing events out of the northern beaches.. I organised one, and the only people to rock up where the northsiders.. So it blew that argument out of the water.
  • Replies 222
Yeah, but two years is also a long time - if I'm proven wrong, so be it but I think we need to mix it up a little!
I just don't think we make anyone else feel like going along to these things when we keep having it over North, and talk about the same people (from the Northern area) coming along?
Oh my god , u serious????
i live in Artarmon!!!!thats soooooo close....i think i know this place , but where is the parking?
Parking is in the next street parrallel to the highway (off mowbray) or on the highway (clearway is over by that time) or the next street.
are you saying you don't want me to come *sniff :crys:
you can still get drunk at the dinner mate. I know I have.
Franky and Duncan still hold the joint title of "King Boozers" from their efforts at Thai Orchid though ;)
Franky and Duncan still hold the joint title of "King Boozers" from their efforts at Thai Orchid though :D
We had to find a new local bottle shop after that last dinner :rofl:
We had to find a new local bottle shop after that last dinner :P
hahaha how come ???
After all the effort duncan put into learning how to use the super chiller.... :D
Anyways on a serious note....
WHERE are we going this months ??
Its only a week away......best to book a few days in advance !!
Cool.. looks like I might finally be able to attend one of these dinners!! Looking forward to meeting you all.
A NewTattoo.. where abouts in Artarmon are you? I'm in Artarmon too :D
Woot i am about a 2 minute walk from there...i also live in that area so ill will most definatly be BOOZING up and rolling home!!!! Ill be there with bells on!!!
7:30pm Thursday 26th, Great Northern. LOCK IT IN EDDY!!!!!
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
