May Monthly Dinner - 26/5/2005 - The Great Northern - Pacific Hwy Chatswood
  • Replies 222
yes..............dinner........
bob are you leaving from work or you going home then leaving from home ??
cause I finish uni at 6...just wanna see if we can arrange a mini cruise to the great northern...hehe..yes I dont know how to get there and wanna follow you :P
nope, gun metal grey GTR. this one:
as to finding us. hmm, well I'm about 6feet tall 300 pounds and white (which probably describes half the people at the northern).
I'm sure you'll find us, just keep asking people if they are from SAU until someone says yes :)
damn thats the ugliest 32 ive ever laid eyes on !! :P
hahaha jk...
richard did you always have them wheels ???
I generally dont like them rims but they look hot on the Rs.....
yep, always had em. I have to admit I thought they looked kind of ordinary too, but once I saw them on the GTR in the flesh I though. hmm not bad. there is certainly no mistaking them for anything other than a Jap race wheel. :P
now, back to dinner...
is there parking at this place?? I dont remember seeing a car park!
Also I think we should all meet somewhere first so that the newbies know who we all are.. Would also be good to know how many people are coming so we can get a table big enough..
ibthisallgoestoshit.
and mmmgtir.. wash that VB wife beater before you rock up. It was vile last time.
and mona.. your a piker.
mona, blow off whatever other lame engagement you have and come to dinner.
mark, sit down before you read this:
no VB at the northern.....
jk. no idea what it cost there as I'm not much of a VB fan.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
