Hey anyone know of anywhere esp. cheap for new tyres in Bris? Or anyone work for a tyre place?
Looking for advice too...need to spend about $200 per corner max what should I get? I've been told Yoko A539 are pretty good for the price and that they can occasionally be found for about $200, although so far I've been quoted $278 each which is why I'm wondering if anyone knows anywhere better - that was at a Bob Jane.
https://www.sau.com.au/forums/topic/72313-tyres-in-brisbane/
Give Jason at Quickfit Yerongpilly a call and tell him Neill suggested you talk to him!!
On a side note, I would also recommend Federal's and if you want something slightly similar and a bit cheaper as far as my memory goes Kumho Ecsta's they are very good with grip and wear!!!
It all depends on what you want and for what purpose. They also stock the new Michelins that are very good but pricing and also BF Goodrich have quite a few good types of tyres in that size
Number is 3217 1188
Thanks for the input guys. Gonna do some calling around this arvo and check prices. Seems like it's really worth ringing around because so far for the same tyres there's over $100 (on all four together) between the highest and lowest quote, and I've only rung three places!!
Checked out Bridgestone Potenza SO-3 which is what is on the car right now but they're like $350 each - no thanks!
From what I've heard the Yokohama C-drive (which replaced the A539) is supposed to be really really good for its price, often scoops the pool when they do road tests. But it's about $250 each which is steep for me...so yeah I'll check out those Federals too.
Yeah I heard the Michelin Pilots are very good too, but bit too expensive for me.
Well after a bit more shopping around I think I'm gonna go with Regal RD-3100's. They're $180 each. I saw them in TTF at Taringa and the tread pattern looked very advanced for a budget tyre. After talking to the guy and a bit of research on the net it turns out that they're a rebadged version of Dunlop SP Sport 9000 which is Dunlops top of the range performance tyre which sells for $400 each and (incidentally holds the world land speed record apparently)!! And they're exactly the same, same tread pattern, even made in the same factory apparently. The only difference is it's a unknown kind of brand: and who gives a toss about the brand name on the side of the tyre :D
A mate of mine had the Dunlop 9000's on a commadore
Good grip, good km's about 50-60000 mostly highway, but they were very noisy.
as darrin has said the dunlop 9000's are not a bad tyre but are very noisy & have been known to get tread bubbling/seperation so be careful going for the cheaper ones as they will most likely not have a replacement plan:ghost:
Try the Mt Gravatt Quick Fit Ask for Tony & tell him Mike Gwilliam put u onto him have your quotes ready & he should beat them (what size Tyres U looking @??)
Just STAY AWAY from those bloody kumos!
Me personally would be spending the money to get a decent tyre. Think of it this way... the tyre is the bit in contact with the ground, if you have the worlds best brakes, suspension etc, doesnt mean bugger all with cheap tyres.
If you can google the tyre you chose, and a few others your looking at, try and find some reviews or something.
And I dont mean to sound rude, but say you had two slicks next to each other, both look the same, black flat, and made from rubber, might be from the same factory, different name, but the rubber is probably different.
I'm was a big fan of the Yoko A539s and like you said they have been replaced
by the C-Drives - I have recently upgraded to the C-Drives and they stick like
a dried turd to a toilet.
Much quieter and smoother than the 539s, and still (and much) grippier in both the dry and the wet.
Yoko's are a little pricey - but you get what you pay for...
Yeah I dunno...I wish I could find someone who has actually used the Regals (as opposed to the Dunlops which I'm 100% sure are excellent). As David said I'm well aware they may not be the same compound, but I'm sure it's comparable to many as it's not THAT much cheaper, and the tread pattern is great. Yep you get what you pay for but at least SOME of what you're paying is for brand name and marketing.
I'd still love to get the Yokos honestly - every single tyre guy along with every person I've heard from that's had either A539 or C.drive says the only comparable performance tyres are about twice the price - that they're comparable with the Michelin Pilot series or Pirelli P Zero.
But $240 difference...
I'll try those places people mentioned but a few places I tried refused to meet the $250 I was quoted by Tyrepower @The Gap.
Oh btw I'm looking at 215/45 R17s. Thank goodness I don't have 18s, nearly fainted when I saw the price of some of them :D
hmm.. if you become a member of SAU you get discounts at bobjane...
I got 225 and 215 45/17 for around the 250-260 mark...
(btw i got the 215 and 225 at the same price - taringa bob jane are pretty good blokes...
speak to "Milton" he is the franchise owner)
interesting tread pattern.... btw the c.drives use a new silcia compound to the 539s.
Hey what's the advantage of wider tyres? Just that you're putting more rubber on the road? Is it a noticeable grip difference? And is it a good idea putting wider ones on the back since then you can't rotate all four?
What kind of price difference is there between say 235 and 215/225 etc anyone know?
Your best bet for prices would be to go into a store and speak to someone direct. As Eug said, if your a member of SAu QLD you get a discount at Bobjane which is nomally quite substantial.
With wider tyres, you get extra grip. I've got 235's on the front and 255's on the back just like most imports. I normally rotate my fronts and backs to either side to get a more even tread wear and long life.
Cars with bigger tyres look fatter as well :(
your tyres not directional erin?
im jack of my car munching tyres
i didnt even get 20k out of my fronts this time and its killing me (235/40s)
time for new suspenion and tyres
ive been going to bob jane at toombul
they do pretty good prices generally
have always bought directional tyres, so havent been able to rotate them;
mite sus out non directional tyres next time. . . .
Oh btw I'm looking at 215/45 R17s. Thank goodness I don't have 18s, nearly fainted when I saw the price of some of them :)
FWIW, on a 17" rim, I wouldn't be going any less than a 235 on the front of a 33... I made the mistake of putting 225's on the front and 255's on the back, and it understeered like crazy... A set of 235's on the front fixed it up...
If your looking to save money, just go with 235's all the way around...
I think its safe to say, dont ask that question in the suspension/tyres/handeling bit... :)
Sometimes wider tyres can have an adverse effect to handleing. I lost the document when we got the new computer. But it comes down to many other factors. Such as rolling resistance, etc. But yeah, up to a point wider tyres will give more grip. But you will find probably a better quality rubber will be more effective.
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
    • Final thought for now. Obviously the reason I was in there was to check everything is OK cooling wise, pull out the radiator to flush it etc, but I have to say the factory has done a hell of a lot of thinking about air management in a way they never did back in the R chassis days. The Redsport/400rs have (from engine forward) 2 large shrouded fans - radiator (incl AT cooler) - AC condenser - Intercooler Heat Exchanger and Oil cooler. There are shrouds and foam around everything to keep it pretty well sealed, which is good in that they have it sorted from factory, and bad in that I can't make any meaningful improvements there. The second red sport pump water pump is mounted in front of the rad in the airflow, so I will see if there is somewhere else I can stash that (unlikely, it is tight in there). The horns which are also in the rad airflow will be moved somewhere else, and hey who needs 2 when 1 would work For track days, I can also remove the lights which would block some airflow. Factory has already taken the smart option of ducting all air that went through the oil cooler down and out of the engine bay. This pic is taken from below looking up, so air comes through the cooler at the top of the pic then hits the shroud and is directed down and out of the engine bay through the engine bay lower cover Which of course is good for oil temps, but doesn't help the rad as it diverts 10-20% of airflow away So, no big improvements to be made here, I'll flush the rad out and put it all back together.....
    • It looks so incredibly busy in there! 😮
    • Next..... That escalated quicker than an Elon and Donald break up! I'll post up a specific DIY for radiator removal on these, but all I'm saying is that if you get a workshop to change your radiator for any reason and they give you a $1000 bill for it, go and hug them and thank them for not charging all the hours it took.....what a bastard of a job. I'll make some adjustments as I put it all back for faster access in the future, but it was a nightmare.
