Hi people....
I have decided to give up my turbo upgrade project as its starting to get too costly for me.......especially since im a student.
I'll just install a power FC with boost controller and it should be good enough for me....i hope.
The turbo was bought second hand and has no shaft play at all!!
Im in Adelaide....so if anybody wants to come check it out, its ok with me :rolleyes:
This is a full kit and this is the t3 flange version which fits skylines and not SR20s.
It will bolt straight on. Everything required is there.
I am willing to sell the HKS turbo kit + 3' downpipe (HKS) + 3 ' front pipe (unknown brand) together!
The turbo has done only 8000kms (as im was told)
Im willing to let go of the whole lot at $1800
Any takers?
You can pm me or email me at [email protected]. You can even call if u want to at 0403671496.
Oh yes....im looking for a power FC boost controller for ECR 33. Anybody with one of them? Willing to trade with cash adjustments of $300? :)
I got some pictures below. The frontpipe is not in the picture.
Cheers
Daniel Tang
Hi,
Im sorry, but i do not know what the technical specs of a HKS 2530 are. However, there are numerous thread on this forum regarding this turbo.
Just do a search. I heard of some ppl pulling 230 rwkw using this turbo at 18psi on rb25det.
I think thats good right?
  • 3 weeks later...
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
