Ive got a near new GT30 for sale. Turbo has done about 3000kms since new. 0.7A/R front, 0.86 A/R rear. Looks brand new. $1700. Its externally wastegated too.
Shaun
0414972596
Price Drop $1500
https://www.sau.com.au/forums/topic/72349-garrett-gt30-turbo-fs/
I had it low mount on an RB20 manifold. I just had to make up a spacer plate and weld it on the standard manifold because the comp cover was too big. This turbo is brand new! It would suit a new turbo buyer; no play at all, i havent even cleaned it, as it is in the pics is how it came off the car. With the 0.86 rear, i think its rated at 600hp. The 1.02 rear is rated at 700hp.
Man, this turbo is about 8 months old; i seriously doubt its an older style wheel. Its an off the shelf Garrett that has not been modified in any way, **** that T04 shit. Its a Ball Bearing GT series Garrett Turbo.
Ill post anywhere at the buyers expense. If you want anymore info on this turbo feel free to contact me or GCG Turbos in Sydney. The turbo is at GCG where they are trying to sell it for me too.
Shaun
0414972596
Ive got a near new GT30 for sale. Turbo has done about 3000kms since new. 0.7A/R front, 0.86 A/R rear. Looks brand new. $1500. Its externally wastegated too.
Shaun
0414972596
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
