Hi,
Been a while since i jump on this forum, quite busy lately with
work... now that I'm shopping around for PFC tuning cost
around Melb... got a question...
Has anyone here got their PFC tuned by Chasers before?
Either by Benny or whoever else who works there...
Preferrably input from those RB owners.... but any other
car PFC result is welcome...
Thank.s
https://www.sau.com.au/forums/topic/72350-chasers-tuning/
  • Replies 63
Ok, everyone has their favourite tuner.:D ... and lol everyones tuner is the best:)
The past 2 months, my car on its current tune, with between 15psi and 18psi on a completely std internal engine has done Sprints at Phillip Island, Sandown and Winton, its done a night at the drags, a day at the drifts at Calder and the engine, tune hasnt missed a beat. And its done a hell of a lot of driving with work since they now know its back on the road proper:(
And Sandown was a 36 degree morning where i was running 18psi and 234rwkws...no pinging, car ran STRONG:) Then it rained so the poor engine was having to put up with big rev spikes with wheelspin as its hero driver was trying to punt it in the wet:whackit:
And on the way to Dimboola and back on the weekend was at 440kms when i stopped at Horsham on the way back for fuel, as i wasnt sure if id make Ballarat. So highway driving id get over 500kms per tank, city it gets to about 400kms before the light comes on.:)
They are the reasons why id be going to Racepace, other may be good, but im comfortable when im at the track and temps start climbing the tune is nice and flexible and can handle hot ambient temps and 103 deg C water temps
https://www.sau.com.au/forums/topic/72350-chasers-tuning/#findComment-1331102
103 degrees... pft soft mate.
I agree with Roy - I had my GTR tuned at Racepace and the car doesn't ping, is efficent (as far as it can be) and stood up well at Sandown on the same day as Roy went out... my issues were unrelated to the tune, rather the hot weather and poor cooling.
https://www.sau.com.au/forums/topic/72350-chasers-tuning/#findComment-1331123
i had mine tuned at chasers. $350. the tune was ok i guess, made a bit more power. massive knock in top of 3rd 4th 5th. over 100 a lot of the times. they dont have a dyno (working yet) so they cant tune it, they just take it to protek to get it tuned and let them do the work. they also lost me keys (no big drama). i had to take it to ice peformance after that to get the knock fixed and have a retune
https://www.sau.com.au/forums/topic/72350-chasers-tuning/#findComment-1331401
What's the problem?
in all honesty i do not know thats y i'm taking it there. Whenever the car creeps above .5 bar it spits and bubbles like crazy. I am guessing too wide a gap sparkies or coil packs. or knock sensor or something, hopefully not too serious. I'm praying its not too serious.
https://www.sau.com.au/forums/topic/72350-chasers-tuning/#findComment-1331661
That was when Dom from Pro-Tek tuned there cars, they are now all tuned by Paul from Motec
https://www.sau.com.au/forums/topic/72350-chasers-tuning/#findComment-1331663
It's not about how much time you have, it's about how much dedication you have.  Ice worked on my car till 5am on Sat morning and moved the car in at 8:30 in the morning.
And look at the results.
That is dedication...
Sorry to say david they dont put that much effort into everyones car like they do to yours...
https://www.sau.com.au/forums/topic/72350-chasers-tuning/#findComment-1331883
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
