i got mine done at protek through chasers, cause chasers didnt have their tuning division set up at the time
ive gone back 3 times for touchups and its still knocking like a ****, i really cbf anymore, when i get some savings freed up im going to ben at racepace, no ****ing around and hopefully get a proper tune done with no hassle.
  • Replies 63
Thank's for the input guys... Not sure if those having issues when the car was tune at Protek due to time constraint (hiring other's dyno cost more not to mention trying to fit in other's schedule) or just a matter of other factor.
I have seen some good results and some bad results from a lot of different workshops.
There are a lot of different prices out there for tunes - but it does generally seem that you often get what you pay for. My guess is generally where a quote is half the price of somewhere else you will be getting half the time spent on your tune.
Be an interesting thing to hear if people know exactly how many runs were done on their tunes? Usually the runs are logged sequentially. I'm pretty sure on my last dyno tune (which was after a significant set-up change admitidly) was finished on run #32.
I'm not saying every tune needs 32 runs to get it right cause I expect most basic re-tunes to need far less. But I'd hate to have my car tuned somewhere that a quote meant "as good as we can get it in 10 runs". I'd rather go somewhere that would take the extra time IF necessary (at my cost obviously) to finish it off completely. And that could be the difference between a pretty good tune and a great tune.
Golgo was serviced and tuned by Chasers last time.
Was good tune - more/smoother power delivery, but as like others - it knocks a bit when running 1.1bar. Turning the boost down a smidge settles this.
just take it to ice performance, never regret it
I will say that Ice is very good in the fact that if you ever have any issues with tunes etc they are more that happy to take a look at it for you at no cost. I have had some minor issues and Nige has been more than helpfull, went to the extend of letting me drop my car at his place and driving it down and back for me! Now thats service!! :(
Just wondering if there is anything that can be done for an automatic with stock computer.
My car gives shitty gas mileage, much more than i'd expect. Wondering if replacing the O2 sensor would help.
This might be the wrong thread to ask.
Also managed to stall the damn autobox this morning. Does it ever few months, coming to a stop sign.
And also been having ongoing issues, with warm starts. doesnt crank over, after a short drive/stop. eg, petrol station.
Since it is automatic, rules out PFC. Think you can only use piggyback fuel controllers, etc.
How do people tune a standard computer?
Been in similar situation. Check fuel filter first.
Drove to Adelaide to get Martin Donnon to dyno chipped std computer at Morpowa as he was the only one I could find to do it.
Car used half the amount of fuel on the trip back at double the pace:)
Since been told "Dr. Drift" does them also but cant comment on outcome.
It IS off topic, there's an article in latest HPI about beefing up an auto. you can trick the auto with an electronic shift kit which will make your auto runs like a manual. you then have to shift it out of drive, 3 , 2, 1 yourself. Better try grab the magazine and have a read, the article is quite informative.
It's not about how much time you have, it's about how much dedication you have.  Ice worked on my car till 5am on Sat morning and moved the car in at 8:30 in the morning.
And look at the results.
That is dedication...
Not everyone has a financial interest in the business....
:) interesting thread... everyone seems to have their own input but doesnt really seem to be an unbiased nor overly constructive type input... more "these guys did mine good so theyre the best"... roys at least has some proven input which is good allbeit completely off the original question.
the original question was, who HAS had theirs done at chasers... not where did u get urs done and how did it go.
its like watching lawyers trying to grab business from someone whos just been hit by a bus or something lol
There should be... MV Automatics in SA should be able to help you out.
http://www.atraonline.com.au/disp_members.cfm?state=SA
I only ment to ask, whether there is any benefit to taking the car to a (performance) shop that knows skylines inside and out. Will leave it be for now.
True :-)
No point for me making a paralel thread.... Genesis Tuning, Race Pace Tuning, etc... it'll be the same replies :-) But I've managed to get an idea from the responses and would aim for the best tuner. After all it's my baby's engine...
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
