Hmm interesting - never been to the WA DPI site before - we must be a lot more relaxed than eastern states guys on some rules. The one that really jumped out at me was how low our cars can theoretically be to the ground!...
For exhausts:
No part of the system projects below the rim lower edge
And for the body kit / lowest part of body its the same:
No part of a vehicle or accessories (except flexible mud flaps) shall project below the lower edge of a wheel rim.
The distance measured from the ground to the lower edge of the reflecting surface of the headlamp must not be less than 500mm
So for 18x7" rims allowed under the "without approval list" on a skyline (or 19's on a GTR or 350Z etc) with low profile tyres that theoretically lets us get the car WAY down low - not the 10cm Ive heard thrown around about the eastern states min clearance and referred to here in the West.
Even better if you are a GTR owner with 18" specced on your tyre placard you can throw on fat 20" rims with about 3cm of rubber - and have your kit and/or exhaust slung as low as 3.1cm :(
Maybe loads of you already know this stuff - so sorry - but interesting for me and maybe anyone else that hasnt seen the rules.
Another one people commonly refer to is to a need to get an "Engineering Certificate" for any mods you do for them to be 100% legal - but in WA it is also wrong - DPI have a list of modifications that you can be down WITHOUT approval, and then a simple "apply before you do it" form to fill out for any other mods that gives you an approval certificate to flash to the cops - as long as you apply before you mod.
Might be less hassle than I thought doing mods.
The worst deal though is for those of us without GTRs - that have tyre placards at a max reommended width of 7" rims. The legal maximum rim WIDTH in WA is 7" - unless you're car is tyre placarded as having came fitted with wider rims (eg GTR) - but even then u cant go any wider again than factory.
That is pretty ridiculous coz they allow you to go up 2 sizes in diamater (eg 16" stock to 18" aftermarket) - but no wider in width - and i aint even heard of a 18" rim thats only 7" wide.
However - of course you probably wont ever get defected for that one coz its hard to tell the rim width if they are stamped on the inside coz the width of the tyres is all they can see with a visual inspection. BUT on that note - keep your 18" tyres no wider than 245s - coz that is the widest legally allowed on a 7" rim - so any wider eg 265s on the rear and its easy to tell for a cop = reads the tyre and checks your tyre placard - so a GTST would get a canary coz the cop can see u are allowed only a 7" rim on your placard and read 265 or 255 on the tyre which is illegal to fit to a 7"... weird system.
More details for anyone else in WA who's never checked it out...
http://www.dpi.wa.gov.au/licensing/myvehic...s/approval.html
is a bugger though - cant go wider than 7" unless the stock specs (tyre placard) allows it.
:P
Or you could go to the DOTARS website, and find out that the car must be no lower than 100mm when lowered, and must retain 2/3 of the suspensions travel.
These regs, I think you will find, apply to ALL of australia, as well as local state rules. The local state rules are probably to ensure loop holes are closed, such as in the circumsance where a 4wd may have side walls that exceed 100mm, it prevents them from having anything lower, so if it gets a flat, that part of the vehicle wont drag on the ground.
As for slacker than other states - in SA you arent even allowed to have a BOV fitted without a full emissions report (IM240) which can only be done at mitsubishi for a cost of over $3000
mine has 17" 255 written as the biggest on the tyre placard
so does that means i can have up to 19" 255's on my car? :(
Yep - but only as wide as the placard also says - is it 8.5" on the placard?? I am actually pretty sure the tyre width is only recommended... you are bound by the ADRs for the width rim shown on your placard... if your placard says 8" wide rims the ADRs will allow only 245s - so your entire placard is wrong for WA laws - see what i mean by how stupid the system is! ... but if the palcard allows 8.5 or 9" then u can go the 255s.... BUT according to the rules you MUST have the same profile tyres back and front (unless specified to have different front/rear combos on your placard - usually only for GTRs/300zx/350Z that came with factory option of diff front rear widths)... so ud need to have 255s on the front as well!
Heres the approved tyre fitments allowed for 18" rims...
TYRE SIZE... APPROVED RIM SIZES(inches)
235/40R18... 8, 8.5, 9, 9.5
245/40R18... 8, 8.5, 9, 9.5
255/40R18... 8.5, 9, 9.5, 10
265/40R18... 9, 9.5, 10, 10.5
225/35R18... 7.5, 8, 8.5, 9
235/35R18... 8, 8.5, 9, 9.5
245/35R18... 8, 8.5, 9, 9.5
255/35R18... 8.5, 9, 9.5, 10
265/35R18... 9, 9.5, 10, 10.5
:P
I'd always stick with the ADR specifications; being at a Federal level, they actually override state-level restrictions, and therefore are grounds to fight any unjust yellows or such if you can actually be bothered.
And anyone with a scanner and a half-decent printer can make a 'new' type placard, if they so want...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
