Neo_R34's has been sent out today. started on 8 more, about 10% done atm, ill keep 2nd post updated on progress. anyone else interested let me know (here or pm) and ill add you to list.
  • Replies 102
ive almost finished the next 8. 7 of them have been tested, and just require the consult connector to be added, and place in box (with lid drilled for led).
webber, bless_you and maximumrpm, ive sent u all a pm.
by the way, this will be the last lot for a while (uni assignments/exams coming up) - at least till july. then ill also be looking into making custom pcb so that i can make a kit for others to put together themselves, to save me time (and theyd cost less obviously for u to put together yourself)
they take too long for me to do them all, especially when i have more exciting things to move on to (including pocketpc consult software).
nate's is completed and sent off today.
3 more almost completed (10mins to finish each off, just add consult connector) and 4 more need box drilled + connector. updated second post.
  • 3 weeks later...
currently pretty hard cause the only instructions/layout id have for it on an excel spreadsheet :) (ive attached a pic of the spreadsheet just if u want to see for urself what im working with atm. the pcb has two lines on the left, with 18 rows across of 4 holes each (seperated by the width of the ICs).
custom pcb would definitely need much easier, would just be much "cleaner"/easier to put together...but id still need to design that and find out how much itd cost
id imagine the kit would hopefully be around the 40$ region, depends on the custom pcb and how confident id be if i got x custom pcbs made that theyd all be used.
please pm me when you are ready to make some more.. put me down for one
uve got 4 more which are close to completion...might be able to finish them on wed. i can put u next on the list?
unless u mean u cant afford it now but in the future?
You keen to send to NZ? i'm very interested, and i know some others who may be interested.
are you aware of the guy making them in nz? might be easier for you to get one from him?
http://www.blazt.biz/300/interface/index.html
edit: box 1 and 3 sold
i also have 3 imperfect/test boxes which are available if anyone wants one for cheaper. note i cant guarantee all of them will dump entire rom (or other extended operations, but less chance of that) without hanging. im pretty sure the first two can (but havent been able to get box3 to yet), but cant actually remember so assume it cant.
box 1: 3 leds (power, transmit/receive), larger box, short cable to proper consult plug (~50cm) and serial plug on box. some serial cables may not fully insert (but still connect...my normal serial cable is fine, but the usb-serial converter, which is fatter, doesnt go in all the way due to other connector on side of it) $35
box 2: no leds (not even power), 50cm to serial plug, 170cm to wires for consult port - no consult plug. need to watch connectors dont break. $15
box 3: one of the boxes i was making in this thread, perhaps due to imperfect component somewhere (dont have time to check/replace everything), i havent been able to dump full rom with it. 50/170cm cable lengths or there abouts, with consult plug. $35
heres the first two:
box2 youd need to be able to hook it up to consult port yourself. this is around or less than cost of components to make them (consult plug itself is half the cost), with the only real downside being possible hanging with long operations (typically rom dumping...potentially normal data logging/viewing/gauges etc could hang, but not much chance of it). i have no real need for them, so thought someone who wants one for cheap that isnt interested in rom dumping might be interested. pickup preferred so u can see it working, but given they are so cheap, cant really afford to provide any assisstance with them.
Peter
  • 3 weeks later...
Update:
Sold two of the test interfaces, only have the 2nd with above, the one without consult plug. Turned out the box3 dumped a full rom without problems to the guy who bought it.
Have completed 2 of the last 3 interfaces, and sent pms to the first two on the waiting list. Once these last 3 have sold ill look into getting custom pcb done to be able to make a kit for around the $40-45 mark that u put together yourself.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
