Still interested in a kit.
Alternatively just a PCB, along with a parts list , schematic, parts layout and how to make the connector etc.
Some of the above seems to have been covered, I know, but the PCB is what is my main concern. I don't want to use experimenters or vero etc if I can help it.
El Bee
  • Replies 102
got an assignment due next friday (or the following, forget). after that ill try make a shot at a pcb then find out about getting it manufactured etc. havent ever made a custom pcb so itll be something new for me (and i dont wanna keep putting it off)
I am also interested please.
NewKleer: I read that the port only appears/works on 1991+ model ECUs. Would an 89 R32 with a later model ECU work you think? Or are there sensors that are not present in the older models?
Mark
im pretty sure if it has the consult port then it will work. very early 89 models didnt, but i believe someone said they did come with them by late 89. to be safe i say 91+ most places i talk about them as ca18's dont have consult, and ca18's stopped in 91. all other nissans i know of 91+ should have it (at least the common ones, pulsar/skyline/silvia/nx/etc)
the consult protocol is designed so that most ecu's only gave a subset of all available sensors, so it shouldnt matter if it doesnt support a sensor here and there (eg ignition timing isnt supported in some s14's or something), as all the other sensors will work
Edited by NewKleer
I'll be making an interface module from just prototype board (Have already got the component layout for the board) in the coming week and intend doing a tech writeup on it - probably end up posted on my webpage. Watch this space... It will be as close to a kit as you can get with you having to buy all the parts yourself.
I just can't get hold of the consult connectors that's all so will likely make up one from ATX power plug (as posted previously in this thread).
Edited by MearCat
Thanks for your reply. When I get the car back I'll check for the port. Cheers
just an update. i got some time over the weekend to start work on thecustom pcb, and ive got a draft one complete. main problem is that i need to make sure the layout is 100% right as theres no room for error since its only economical to make large manufacture runs as theres like a 70-100$ overhead
the other issue i thought about was whether it would be useful to have the serial connector on the pcb, and u plug the actual device right into the laptop (its not that big). only problem is it would need some kind of custom enclosure which has a serial port slot on the end. ive no experience with custom plastic boxes or anything so at this point the pcb design is similar to the current ones ive made, but will have removable cables (i might make the cables myself as they would be the trickiest part, but still undecided on that)
when i get home tonight i can post a screenshot of the pcb design that has the serial connector on board, if anyone knows where to find/make a custom enclosure for it, then youll have an idea of the size im after (only a touch wider than the serial port connector)
heres an example (interface2.jpg) of what the interface could look like if i can find (or find somewhere that can make) an enclosure thats could fit around this. then there's only one cable coming off it, and it plugs straight into serial port (wouldnt be much bigger than a serial plug)
interface1.jpg is the current one im working on, assuming i cant find any better box to put it in.
edit: interface3 is a test for possibly putting it in a parallel port connector shell (but with serial plug)
Edited by NewKleer
normal sized - i decided that smd is going to be too difficult for most people to solder. normal sized shouldnt prove too hard.
as long as it has a consult port it should work. dumping rom can be temperamental, but if u have problems then calumsult can resume dumps
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
