I have a Rockford Fosgate 200m Monoblock amp for sale if anyone is interested in having huge sound pushing out of their subs.
I'm asking for $450
People who know their sound systems know that rockford are the GOD'S
Legendary Rockford Fosgate performance in a mono full-range amp. Stand back, here comes the Punch 200M! This single-channel rocker kicks out 100 watts RMS to a single 4-ohm speaker, doubling its power with a 2-ohm load (two 4-ohm subs wired in parallel, for example). When you want Mr. Bass in the building, activate the powerful built-in low-frequency boost, switchable to 0, +6, or +12 dB at 45 Hz.
100 watts RMS x 1 at 4 ohms
200 watts RMS x 1 at 2 ohms
requires 10-gauge power and ground leads wiring and hardware not included with amplifier
selectable 50-210 Hz variable low-pass crossover, 12 dB per octave
TRANSana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
MEHSA provides more efficient transfer of heat from MOSFET output devices to the heatsink for cooler operation
TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise
NOMAD advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
switchable Punch Bass boosts bass +6 or +12 dB at 45 Hz
dimensions: 10-1/2"W (7-13/16" without endcaps) x 2-7/16"H x 9-7/8"D
Anyone interested call me on 0402329701 or email [email protected]
aDaM cAmLz
(sydney)
Slipery while Boosting
https://www.sau.com.au/forums/topic/72403-rockford-fosgate-200m-monoblock/
    • Stock ECU has compensation, you won't damage the engine. Personally I recommend getting an acceptable catalytic converter, it doesn't need to be OEM and super expensive but a cheap universal one to keep it from being super obnoxious to be around. Decatted cars smell pretty awful.
    • Correction. Ignition was on before, but I guess the car had to be running for it to work.
    • The stock ECU won't care. The gains from Nistuning the ECU and then "optimising" the fuel and ignition tables will be about 2 more HP.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
