  • Replies 116
Hey where abouts in melbourne r u? Do u still have the inside air conditioner air vents if so how much will u sell them for becos i need 2 put them in my car so it can pass a road worthy can u please call me on 0413442008 catherine after 4.40pm thanks
I'm after the abs unit with all brake lines, rear grab handles in the interior, rear seat belts, rear winscreen wiper, and the plastic that goes under the front bar and front of the gaurds. Could you pm me a price with your mob no since I lost your home no.
QUOTE (>GoDziLLa<)
Decided to seperate parts from smashed GTR
HKS twin Airpods - $150SOLD
Nismo strut brace - $200SOLD
HKS oil cooler+Oil filter relocation kit - $550SOLD
Volk Racing three spoke 17*9.5 Wheels - $800SOLD
3 inch front pipeSOLD
almost brand new highflow cat - $200
bonnet and latch - $450
bootlid and spoiler - $250
right front guard - $200
left front guard little damage right on edge - $100
front bar + lip - $200  SOLD
front bar reinforcement - $200 SOLD
headlights - $250 each
Set of genuine mats $80
front blinkers $100 - eachSOLD
rear taillights and surrounds set - $250
KYB Ride Adjustable street use suspension - $800
front brake calipers with pads - $400
Rear calipers with pads - $200
HKS old style boost controller - $130SOLD
Essential Jap tuned ECU, 8200 limiter no speedcut - $180
rear diff - $600
Gearbox - $900
Engine and loom RB26DETT 150,000kms brand new iridium spark plugs
and O.S Giken cam gears(not sure though) good condition  $4000
O.S Giken Twin plate clutch good condition never slipped $1200
Brand new 2 rear brake disc rotors $300
rear driveshafts $300
centre console piece with the 3 gauges $80
driver side door complete $350
Fuel pump $200 SOLD
Windscreen(with built in aerial) $300
Rear window $200
All prices negotiable,
can do good deal if someone buys engine,gearbox and clutch at same time
Please ask if you want pics of certain parts
Hi, Do you still have bonnet and bootlid? If so, what price will you take for both?
Thanks
26 Motorsport
Hi,
Also after your guards too, condition not an issue, for a race car. Can bring around cash and pick up from you when you're available.
Call me 0407 322110
26Motorsport
I'm intrested to bye these items.
Contact me on 0405595035.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
