I just purchased a aftermarket fuel regulator, and will fit it this weekend...i have 2 questions.
1. Should i remove the standard fuel reg or just put a line off it to the new one and then to the fuel rail
2. Also the regulator has a gauge that reads from 1-10psi, what should i set it to if the car is running close to 200rwkw
Cheers
https://www.sau.com.au/forums/topic/72475-aftermarket-fuel-regulator/
10psi... wow it's going to rip the needle of when you turn the key :cheers:
Check stock fuel pressure. Remove stock FPR, install new one where old one was, start with stock fuel pressure. Go to a dyno.
If you leave the stock on there.. you can only increse fuel pressure. In some cases you buy an aftermarket one to learn your car off.
