i have the Rb20det, neways i was at the traffic lights and then all of a sudden the car turned itself off 4 no reason at all the revs didnt slowly drop they just went straight down and then happened again at next light and that time it took to cranks to get her firing again...................then drove perfect and still to today nufin but this prob happened once 6 months ago?????? ne ideas 3 times = me try fix!!!!!
so help nebody appreciated :bs!:
https://www.sau.com.au/forums/topic/72505-r32-switched-off/
well intresting u say that the first one sounds simular i had an intermittent miss and the turn off but dint think related after mechanics trying no good i thaught i might play n stop being lazy neways wen i pushed the wiring loom plug into the coil with force it cum good and then miss neways i change the c/pack but i think i bent the age old wiring all the way back wonder if that had nething to do wif da fix......... mayb should just replace those whole wiring loom :headspin:
https://www.sau.com.au/forums/topic/72505-r32-switched-off/#findComment-1335602
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
