Howdy all,
My heater/climate control unit does not seem to function properly. I only get cold air at 18'c or hot air at any tempertaure above 18'c.
I tried the settings with the a/c on and it made little difference (i.e. the air-con worked but still only left me with hot or cold - so settings in between).
I also tried running the diags and everything appeared normal for most of the settings. When I put it to the sensor check, where the number "5" appears, I pressed the window de-fog button (bottom right next to the recirc button), and i got a reading of between 18'c and 21'c for the first setting (which I assume is the inside air temp - seemed about right), and I got -30'c for the second (no idea what this reads).
Anyone got any ideas? It kinda sux only having a hot or a cold setting, because the climate control does not function properly....
https://www.sau.com.au/forums/topic/7253-heaterclimate-control-temp/
Behind the little slits in the centre console that look like
type thing...
There's a climate control temp sensor.... It should have an electrical plug and a suction hose connected to it... make sure bith of these are connected.....
Doc.
Tool the calibration in the climate controll is out or the external temp sensor is faulty. the climate control thinks the out side temp is -30 so it wants 2 blow hot air to warm the car up. try resetting the climate control (same way as rebooting the ecu) i think that should work. if not then need a new external temp sensor.
hope this helps
I've got the same problem..... where would I find the external temp. sensor??? :confused:
I'm guessing it's somewhere at the front of the car since thats where all the damage from 'the accident' happended, and before that it was all working :D
You'll find the external temp-sensor just under the horn.
At the very front of the car (in the middle).
It's black and is about 3-4 cm's long...
Hope that helps. (I had to re-locate mine as I installed an FMIC).
Cheers
Rob
  • 1 year later...
The external temp sensor on my r32 was on the frontbar just behind the number plate.
it's a black little like box, with a metal bracket on it, and a bit of wire.
mayb unplug it, clean it out, u may need to replace. Not sure how it works,
i think the sensor is an active sensor, so it might work from a voltage return.
or it might work by resistive.
I know when i diconected mine to see what would hapen it showed -30'C.
So check the wiring on the plug, move it about....
u may need a new sensor, or your wires shaged or mayb where ever it goes into is disconected or shaged.
Good luck.
Good luck.
Madtrang,
I had a look and was able to find the sensor.
I am little curious as to how you disconnect it. Mind you I was using a blue led light in a car park (really hard to see but better then nothing), as I couldnt find a torch.
It had a cable coming out one side with tubing around it, and the otherside had the bracket connected to it.
So if you could give me any help with disconnecting/reconnecting it that would be fantastic!
-Alex
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
