Cars You have Owned So Far...
I thought why not have a thread where members can tell other members what cars and bikes you have owned so far. Ill start with with what ive owned since getting my L's hopefully in order.
1st: '88 Pulsar
2nd: Either VP SS or VL Turbo... yes i know they're Holdens, but the vl had a skyline motor in it! if it didnt, then i wouldve got a skyline!
  • Replies 83
1. Datsun 120Y while on Ls and paddock basher
2. Mazda 323 '82 shitbox while on Ps
3. Mits Mirage in last year of Ps until sum1 t-boned me (not my fault)
4. Nissan Skyline R33 gtst
time to time used parents cars: Mits Pajero, VX SII Commondore S, BA V8 fairmont.
owned
'87 MA70 totyota supra with a 7M-GE and all its headgasket-blowing goodness...
'92 R32 GTSt
and have driven the family's cars: mum's R31 skyline (learnt in this on my L's), bro's 300zx TT, dad's 86 corvette (not much though)
Warren.
1. on L's / early P's - Alfa Romeo Giulietta 1.8L shitbox
2. still on P's Alfa Romeo Alfetta 2L nice car
3. end of P's til early this year - NA R33 2.5L
4. mid last year til now - R33 GTS-t
VL when i was 15,
33 GTS NA on my learners till mid last year
Same 33 with V8 conversion
'95 R33 GTR Vspec Last July
Still own both skylines, GTR is for sale.
1. 56' Dodge coupe ute (f100 size) very cool and rare... sold it...
2. Morris minor
3. 71' Triumph Daytona T100R (500cc light and fast :cheers: )
4. mk1 2 door escort
5. L300 express (AKA the 'sin' bin :()
6. XE falcon 6cyl sedan
7. XD ute tough 302
8. KC laser
9. umm 89 EA ghia
10. ZZR
11. toranna
12. another ghia (hey - i liked plush at that time... and it was a drive car:) )
13. 32 GTR
had a LOT of paddock bashers + a race corolla.
plus all the other cars that belonged to my parents....
ok lets see
1. 1980 Ford Escort Mk 2 with 1.3L motor changed to 1.6L (Manual)
2. 1979 Ford Escort Mk 2 Ghia 2L Auto (YUK!!!!! AUTO)
3. 1984 Suzuki Swift GL 1.3L with a G13B 1.3L twincam conversion (THIS BECAME FAIRLY QUICK WEIGHING IN AT ONLY 650KG) (Manual)
4. 1994 Suzuki Swift GTI 1.3L with big cams, extractors, sports system, intake and chipped ecu (Manual and for sale)
5. 1992 R32 Skyline GTST (Love this car) (Manual)
thats my list to current date
longest i have owned a car was about 15months but this one ill have longer, and no i have never written any off i actually still have number 3 at home aswell...lol
keep this thread goin guys and girls
Ok here is my list.
1- Datsun 180B ($1400 worth and went pretty good, SSS motor with twin carbies)
2- VN Commodore (not the smartest move, but it was a decent car)
3- Festiva Treo (Won it in a Raffle, Wow, people actually do win cars)
4- ZZR-250 (Wanted to have a go on a bike)
5- FTO GPX (great looks and first taste for import - for sale)
6- GTR R32 (and I thought the FTO suspension was stiff)
Next car will either have to be a convertible or a luxuary car.
1. 1987 - Honda Accord >> 6 months
2. 1988 - Toyota Celica >> 2 Years
3. 1997 - Toyota Celica >> 1 Year
4. 1988 - Mazda MX-6 First Gen. Turbo >> 2 Years
5. 1989 - Skyline R32 GTR >> 8 months and counting....
1. DR30 with the 2.4E NA But still went hard
2. HR31 Passage GT (4 door) with the 93 silver top RB20DET Running 11.5 Psi
Full 3" exhaust
NEXT CAR TO HAVE
3. R32 GTR (93)
4. R33 GTR (97)
5. R34 GTR (2000)
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
